marlb
routerboard 1000 dead after reset c229 configuration
Wed Jun 22, 2011 7:24 am
routerboard 1000 dead after reset c229 configuration.
It cant even boot pass 1st kernel router layer. Anyone encounter that before??
sergejs
Re: routerboard 1000 dead after reset c229 configuration
Wed Jun 22, 2011 9:34 am
Provide us with console output you get from RouterBOARD 1000.
Have you tried to reinstall RouterBOARD by Netinstall?
comaco
Wed Nov 30, 2011 11:18 am
Hi all.
We have exactly the same problem with one of us RB1000. After a reboot (order in the Winbox to restart the system), the RB1000 is not responding.
We use the console to connect it, but it doesn´t show anything. We can´t connect to the Boot loader because it doesn´t show.
Someone had the same problem and could help us?
Thanks in advance.
MichelePietravalle
Trainer
Trainer
Tue Jan 03, 2012 10:06 am
i have a similar problem on a routerboard. i need to perform two reboot in order to have properly running rb/1000. in console log a have some messages regardin kernel crash, i will post i next days.
a netinstall will fix all.
BruniderBruns
Thu Mar 14, 2013 10:00 pm
Hi all.
Thanks in advance.
Exakt the same problem. Any Ideas?
BruniderBruns
Thu Mar 14, 2013 10:14 pm
I have a other routerboard in the same local network. Can i try to boot it from the other routerboard?
Users browsing this forum: No registered users and 16 guests
