felici
RB1100AH power cycle required on upgrade
Tue Jun 28, 2011 2:31 am
We have performed several software upgrades on our RB1100AH, after each system... restart, it does not come back online, and has required a power cycle to bring it back. We did the most recent installation of ROS5.5 today, and had a console port plugged in to watch if there was any indication of a problem.
Again, after system... restart, the RB1100AH did not come back online, with "Restarting system" being the last message on the console. After a power-cycle, the router comes back with the new ROS just fine.
Here is the output of the console during the upgrade...
> system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Rebooting...
Stopping services...
verified routeros-powerpc-5.5.npk
installed routeros-powerpc-5.5
Restarting system.
(STOPS HERE AND REQUIRES POWER CYCLE)
RouterBOOT booter 2.30
RouterBoard 1100AH
CPU frequency: 1066 MHz
Memory size: 2048 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
mount: Mounting ubi0:Kernel on /boot failed: No such device
Starting services...
MikroTik 5.5
specifications:
uptime: 22m28s
version: 5.5
free-memory: 1524848KiB
total-memory: 1555428KiB
cpu: e500v2
cpu-count: 1
cpu-frequency: 1066MHz
cpu-load: 6%
free-hdd-space: 482340KiB
total-hdd-space: 520192KiB
write-sect-since-reboot: 233
write-sect-total: 104419
bad-blocks: 0%
architecture-name: powerpc
board-name: RB1100AH
platform: MikroTik
/system routerboard pr
routerboard: yes
model: 1100AH
serial-number: 2C77014495E0
current-firmware: 2.30
upgrade-firmware: 2.30
Any suggestions?
gmsmstr
Trainer
Trainer
Re: RB1100AH power cycle required on upgrade
Fri Jul 01, 2011 11:47 pm
WE have seen this on a number of boards in the newer v5 hardware. I would let it reboot and send a supout to MT.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
leo_cakep
Sun Jul 03, 2011 11:13 pm
it's also happen on my rb1200 :D
but i think it isn't a really big problem...
after upgraded, my RB just work normally, even each reboot
Ibersystems
Mon Jul 04, 2011 12:16 am
Leo, you only have one local board is it?
Imagine you have to upgrade 50 customers at 300 km of you and you have to call them to power cycle the main firewall.. xDDD
They will say: WTF¿?!
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
jcrites2008
Wed Jul 06, 2011 1:23 am
This happened to me a couple times on 2 rb1200's. I think it happened when I upgraded both of them. One time it happened when i reset the config with the no-defaults option too.
webguyz
Wed Jul 06, 2011 2:22 am
Just happened to me on RB1200 upgrading from 5.2 to 5.5. Did this remotely so I had the remote hands guys unplug the rb1200 and plug it back in and it still would not come up. Finally I had my tech go down to the datacenter and unlplug the power and wait for almost a minute before plugging the power back in. After that it came up on version 5.5. Did some more testing and found if you put the power plug back in too quickly after pulling it the RB1200 will not boot up. Strange stuff.
normis
Wed Jul 06, 2011 8:52 am
please make a supout.rif file and send to our support email so we can find the problem
Hotz1
Fri Jul 22, 2011 8:27 pm
The same thing is happening here, on an RB600 that I dusted off and started testing. Once I upgraded it to 5.5 using netinstall, it started giving this same message during every boot:
Starting...
Upgrading to the latest firmware made no difference. supout.rif on the way to support@mikrotik.com...
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Users browsing this forum: No registered users and 1 guest
