Alfabi
RB1200 - errors on ethernet ports
Mon Aug 01, 2011 11:56 am
hi guys, im just receive new rb1200 installing 5.5
doing configurations and receive o lot errors on 100 mbit ports with POE + MPLS, before upgrade all working fine on rb493 -(
any rec ?
http://www.bios-computer.com - Fastest WISP in UA
kirshteins
Re: RB1200 - errors on ethernet ports
Mon Aug 01, 2011 12:17 pm
What do you mean by POE in this case? RB1200 cannot be powered with PoE.
Alfabi
Mon Aug 01, 2011 12:22 pm
im mean, connect to 1200 - 100 mbit Rb 411Ah over POE on eth7 and eth8
normis
Mon Aug 01, 2011 12:30 pm
Why do you plug in PoE into RB1200 ports 7 and 8? RB1200 does not support PoE
kirshteins
Mon Aug 01, 2011 12:43 pm
Alfabi
Mon Aug 01, 2011 12:53 pm
this is so bad, im was in planing concentrate seven remote 100 mbit devices Powered by PoE ( before was 493ah and was to slow and slow Out only 100 mbit) as, im understand, im cant do this task? and your rec is 493G ? im right?
normis
Mon Aug 01, 2011 12:55 pm
I don't understand what you are trying to do? please make a network diagram of how you connected. Maybe we simply misunderstood you.
Alfabi
Mon Aug 01, 2011 1:09 pm
im try build like this
kirshteins
Mon Aug 01, 2011 2:32 pm
We found a bug in statistics and we will fix it. Let us know whether there are problems with throughput or latency.
Alfabi
Mon Aug 01, 2011 3:08 pm
present problems with throughput, im cant access via winbox on remote 433ah over 1200,
(im think trouble with mtu in MPLS ) horewer mpls and ospf is up, mactelnet is work,
so a lot lost packet via speedtest, different errors going up in statistic in different field, but then im turn off
mpls and do one bridge everything work fine
so, hard to explain with my poor English -( a lot of experiments one day is Out
Alfabi
Thu Aug 04, 2011 5:49 pm
BUG with max mtu migrating to 5.6 -( but statistics works, im see only FCS errors -) so maximum MTU in mpls configuration is 1500
Users browsing this forum: No registered users and 35 guests
