MUM Europe 2020
popcorrin
RB493G fan control?
Thu Aug 25, 2011 3:40 pm
I have a fan hooked up to the header on my RB493G. I was wondering if it was possible to control it manually or better yet since the 493G has a temperature sensor, it would be nice to control the fan using the 493G as a thermostat.
sergejs
Re: RB493G fan control?
Thu Aug 25, 2011 4:27 pm
There is no too much you can control,
fan-mode – whether to use automatic fan failover (auto | manual; manual by default).
use-fan – which fan to use in manual mode (main | auxiliary; main by default).
only active-fan. More information about fans in RB493G User Guide,
http://routerboard.com/pricelist/downlo ... ile_id=316
popcorrin
Thu Aug 25, 2011 5:02 pm
Any chance that more control could be added in the future?
Also, under winbox on the 493G there isn't any options for the fan. I see those options under different routerboards but not the 493G.
sergejs
Fri Aug 26, 2011 11:08 am
Highly unlikely for RB493G. Maybe for different boards.
popcorrin
Sat Sep 03, 2011 10:15 am
How about at least adding the standard fan control for the 493 G like the other boards have. It's missing in winbox.
normis
Mon Sep 05, 2011 10:13 am
the more high end boards have more control, but they are also more expensive.
popcorrin
Wed Sep 07, 2011 6:21 am
The standard RB433 and the RB493AH have the controls I am asking for. The RB493G has no fan control whatsoever.
normis
Wed Sep 07, 2011 9:08 am
I just checked. They also have the same two settings "fan-mode" and "use-fan". What "control" are you talking about?
popcorrin
Fri Sep 09, 2011 12:31 am
Those are the controls I am talking about. Under v5.6 using winbox, those controls are not available on the RB493G.
sergejs
Tue Sep 13, 2011 2:47 pm
Yes, you are correct /system health menu is empty. We are checking the problem.
sergejs
Tue Sep 13, 2011 3:34 pm
Problem will be fixed in the next RouterOS version for RB493G and fans control.
Users browsing this forum: No registered users and 52 guests
