honzam
NEW 711G-5HnD
Fri Sep 09, 2011 5:55 pm
Normis: Thanks.
Antenna Connector: 2x MMCX
CPU: Atheros AR7240 400MHz network processor
Memory: 32 MB DDR SDRAM onboard memory
Ethernet ports: One 10/100 Mbit/s Fast Ethernet port with Auto-MDI/X
MiniPCI slot: none
LEDs: Power, NAND activity, 5 user LEDs
Power options: PoE: 8-30V DC on Ether1 (Requires RBGPOE PoE injector for Gigabit mode, with regular PoE injector, will work in 10/100 mode)
Power Consumption: Up to 4.5W at 18V full load (0.245A)
Supported OS: Mikrotik - RouterOS Level 4
Licence: RouterOS Level 4
Receiver Sensitivity: 802.11b -92 dBm @ 1Mbps, -87 dBm @ 11Mbps, 802.11g -90 dBm @ 6Mbps, -70 dBm @ 108Mbps
Wireless: Built in 5GHz AR9283 802.11a/n card 2 MMCX connectors
http://www.mikrotik.com/download/share/rb711G_5.pdf
LAN, FTTx, Wireless. ISP operator
Muqatil
Trainer
Trainer
Re: NEW 711G-5HnD
Sun Sep 11, 2011 1:58 am
The pic on the PDF is a RB711-2Hn :lol:
Renato Bernardi
skype: medtech5
InoX
Re: NEW 711G-5HnD
Sun Sep 11, 2011 3:32 am
RB711-2Hn is not dual chain
RB711-2Hn does not have usb
RB711-2Hn does not have power jack
...only the name in the picture, maybe is writen with Paint.
roc-noc.com
Forum Veteran
Forum Veteran
Re: NEW 711G-5HnD
Sun Sep 11, 2011 4:16 am
That is actually a picture of the new RB711UA-2HnD. We just received them last week.
http://www.roc-noc.com/mikrotik/routerb ... -2HnD.html
Tom
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
honzam
Re: NEW 711G-5HnD
Mon Sep 12, 2011 1:00 pm
When can we expect at the distributors?
honzam
Re: NEW 711G-5HnD
Fri Sep 16, 2011 12:26 pm
No info yet?
Vaako
Re: NEW 711G-5HnD
Sat Dec 17, 2011 10:12 pm
What for antenna's would you suggest for the RB711G-5HnD ???
Regards,
Vaako
roc-noc.com
Forum Veteran
Forum Veteran
Re: NEW 711G-5HnD
Sun Feb 26, 2012 11:59 pm
Just use the built in (internal) antennas. Unfortunately, the design to support external antennas is not done very well.
Tom
888-762-5662
cbrown
Trainer
Trainer
NEW 711G-5HnD
Mon Feb 27, 2012 12:43 am
Tom
I think he means for the 751 series. We use the arc panels for 711G-5HnD and they have worked great.
http://www.roc-noc.com/arcwireless/ante ... /dual.html
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Users browsing this forum: No registered users and 31 guests
