MUM Europe 2020
dragon2611
RB751-U-2nHD 100% cpu
Sun Nov 13, 2011 3:14 am
I seem to have a problem with my RB751-U-2nHD where it will spike to 100% CPU usage and sit there for several minutes making it almost totally unresponsive, if watchdog is enabled it will then eventually reboot itself.
I do have an SSTP tunnel established, however I don't think it's encryption causing the CPU spikes as there shouldn't have been any significant traffic on that interface, infact Cacti shows 100Bits/s which is presumably is just background traffic to keep the link up, but may have missed some polls due my RB being unresponsive at the time.
The RB is connected to 2 ADSL2+ connections and is doing PPPoE for one of them but again there wasn't much throughput on either of them at the time as far as I can tell.
Is there a way to find out whats causing the sudden high load?
cbrown
Trainer
Trainer
Sun Nov 13, 2011 3:42 am
Use Profile. It's under tools.
/tools profile
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
dragon2611
Re: RB751-U-2nHD 100% cpu
Sun Nov 13, 2011 3:47 am
Thanks I'll try that next time it happens (providing I can actually login to the RB of course)
I'm wondering if it's related to this http://forum.mikrotik.com/viewtopic.php?f=1&t=47655 as I do use SNMP from a Cacti server to graph my bandwidth usage over time.
Running 5.8 but also had it on 5.7
cbrown
Trainer
Trainer
Sun Nov 13, 2011 5:48 am
More than likely yes. We were running into the same issue with our 1100
C.Brown
normis
Mon Nov 14, 2011 12:27 pm
we need more information to figure out what causes this. If anyone has the same issue, please look in the "/tool profile" to see what consumes the CPU. If possible, and if the device is accessible, make a supout.rif file when this happens.
cbrown
Trainer
Trainer
Mon Nov 14, 2011 4:42 pm
I didn't get a supout but I did look and it was DHCP running on 5.8.
C.Brown
dragon2611
Tue Nov 22, 2011 12:51 am
Hi Normis,
I couldn't get a sup-out as I got kicked out of winbox before I could run one, watchdog was disabled so it wouldn't have run one and in the end had to give up and powercycle the RB.
However I did manage to screencap this before It threw me out.
Edit:
Turned watchdog back on (I had turned it off when I was playing at one point and never re-enabled it) and set it up to autosupout and hopefully to also email me a copy of it.
If we're lucky it will generate a dump just before rebooting itself.
normis
Tue Nov 22, 2011 7:55 am
your disk activity is through the roof. are you running a proxy server there?
dragon2611
Tue Nov 22, 2011 2:39 pm
Nope no proxy enabled
Has a couple VPN tunnels and usually 5 - 10 wifi clients
Can't think of much that needs to be written to flash
laurinkus
Thu Nov 24, 2011 11:20 pm
I have the same problem with RB751-U-2nHD running on 5.8
In my case web proxy is enabled but cache is set to 0. I use it only to block certain URLs.
I've noticed that router freezes from time to time. At the same time when it freezes flash usage goes up to 100%.
> /ip proxy export
/ip proxy
set always-from-cache=no cache-administrator="" cache-hit-dscp=4 \
cache-on-disk=no enabled=yes max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
/ip proxy access
add action=deny disabled=no dst-host=... redirect-to=....
Previously I was running the same configuration on RB150 and had no issues.
dragon2611
Sat Nov 26, 2011 5:43 pm
I was adding an Ovpn client interface when I lost connection.
It looks like watchdog rebooted the router, have raised a ticket with the autosupout.rif attached in the hope it will help MT track down the problem.
injuredx
Thu Nov 08, 2012 10:41 pm
just quick question guys.... when hotspot service is enabled, did proxy service also automatically enabled? although when we disabled it before?.
i have the same issue 100% on flash too... makes the connection errors to my clients..
i have hotspot service enabled.. but not proxy... it show that when i check with " / ip proxy print " the result is " enabled : no "
BUT... when i cek my log...
it show that the proxy is active!!!..
are this the "cause" of 100% flash?
if not... / or
anybody using firewall filter rule to block connection to certain address?
sorry for my poor english
mschafer
Fri Mar 15, 2013 6:39 pm
Has there been a resolution to this? My cpu is 100%. over 60% is unclassified. I did get a a supout.
uldis
Fri Mar 15, 2013 7:46 pm
make sure you are using the latest RouterOS version.
PastuhMedvedey
Mon Mar 18, 2013 9:46 am
http://forum.mikrotik.com/viewtopic.php ... 57#p346857
RB751U-2HnD, RB2011LS, RB1100AH, RB433, RB411GL, RBSXT, CCR1016
mikruser
Fri Nov 10, 2017 10:12 am
ROS 6.39.3
also have this issue:
do not ask me why it is necessary.
mikruser
Wed Jan 24, 2018 6:20 pm
any comments from Mikrotik?
jarda
Thu Jan 25, 2018 1:32 pm
Any issue description?
mikruser
Thu Jan 25, 2018 2:03 pm
you do not see first post?
jarda
Thu Jan 25, 2018 2:12 pm
You have tried to post a picture but it doesn't display. So your problem is not clear.
mikruser
Wed Oct 03, 2018 6:51 pm
6.43.2 also have this issue
Users browsing this forum: No registered users and 34 guests
