askanazus
RouterOS USB Power reset
Fri Dec 09, 2011 2:32 pm
Does the RB750UP support RouterOS USB Power reset function ? If not, what devices support that ?
normis
Re: RouterOS USB Power reset
Fri Dec 09, 2011 2:36 pm
No. Currently only SXT and Omnitik has this.
askanazus
Fri Dec 09, 2011 2:50 pm
Thank you very much!
askanazus
Mon Dec 12, 2011 2:54 pm
Do you plan to make device like RB750 with this function ? Because we need to use mikrotik as 3g router end we don't need wireless or antennas on STX or Omnitic. Hey are bigger and have specific design wich is making inpossible to use them at SOHO environment. Or can we put the motherboard of omnitk into another case without antennas ?
Users browsing this forum: No registered users and 58 guests
