adilazzubaidi
RB 133 LOSE LICENSE
Sun Jan 08, 2012 11:18 pm
hi all , after update my rb133 by netinstall, software ID was changed and license was lost please help me to get one.
nest
Forum Veteran
Forum Veteran
Re: RB 133 LOSE LICENSE
Sun Jan 08, 2012 11:35 pm
when you ran netinstall, did you accidentally remove the licence key from the screen, where it says "Key:" near to top right thus effectively telling it to remove it? If so, too late now of course, but never do that. :-(
If you give an email to support@mikrotik.com with your software ID, they can send you the correct matching licence key and you can then paste the text you send you back into the running routerboard via telnet or winbox.
Switch it off as it will make even more difficult for you after 24 hours of usage. So if you switch it off after playing with it for 1 hour today, then next week you still have another 23hrs to play! It only counts down with 'uptime' but does not when switched off.
Ron Touw - Mikrotik Certified Trainer
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/category/166
Largest Official UK MikroTik Distributor
adilazzubaidi
Mon Jan 09, 2012 9:46 am
thanks , I will sent software ID to Mikrotik support
lordiceman
Mon Jan 09, 2012 5:49 pm
solution to your problem is here in this thread http://forum.mikrotik.com/viewtopic.php?f=2&t=58049
nest
Forum Veteran
Forum Veteran
Mon Jan 09, 2012 7:01 pm
Yeah, I already tried that, but it didn't work, it said the key was not found. Which is why I suggested he contact Mikrotik as best solution. ;-)
Users browsing this forum: mikroru, petrb and 8 guests
