MUM Europe 2020
Mrhot2000
r52hn antenna question
Wed Jan 18, 2012 8:41 pm
I want to use r52hn with my 433uah Question is that this mpci is mimo and has two connectors but i want to attach just one sector antenna. will it work allright ? or should i attach another antenna ?
server8
Re: r52hn antenna question
Thu Jan 19, 2012 12:59 am
One antenna is ok
Giuseppe
cbrown
Trainer
Trainer
Thu Jan 19, 2012 3:01 am
One antenna is fine but make sure you use chain0 and leave chain1 disabled.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Mrhot2000
Thu Jan 19, 2012 10:15 am
One more question. I have my client end at around 1 mile away clients use tplink 7200nd attached to tplink 9db yagi antena. I have two choices of antennas one is alfa 15dbi omni antenna and the other one is a 16db alfa sector antenna. Data Provided to clients in just 2mb each which antenna would be best for my case
WirelessRudy
Thu Jan 19, 2012 10:56 am
See your client as a reader in the library hall. Your AP as someone to provide him with some light. This last can use a lightbulb with certain strenght or a slighly stronger torch. But both give enough light to serve the reader......
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
Mrhot2000
Wed Jan 25, 2012 6:32 am
One More Question Can I use a Dual Polarized Sector antenna with this mpci as it has 2 chains needed for the antenna ??
WirelessRudy
Wed Jan 25, 2012 11:10 pm
Yes, you can
Rudy R. Puister
Users browsing this forum: No registered users and 10 guests
