Mrhot2000
r52hn power offset ??
Thu Jan 19, 2012 5:24 pm
when i set the card power to card defaults it shows 17db. whats the max safe power i can set on it at all rates ??? i Want max without damaging the card.
changeip
Re: r52hn power offset ??
Thu Jan 19, 2012 7:42 pm
the default is the max.
Mrhot2000
Fri Jan 20, 2012 8:00 am
the mikrotik website states the card as 25dbm. The card setting is 17dbm 8 db is a lot of differance I would have set it to 25 but i have been told that some cards have power offset and transmit at higher powers then they show so i wanted to know where to set the card or should i just live with 17dbm
changeip
Fri Jan 20, 2012 9:30 am
look under the tx powers tatus tab and find the actual to see what its using.
uldis
Fri Jan 20, 2012 5:29 pm
this cards doesn't have any offset. Check the country setting or frequency-mode setting.
Chewers
Fri Jan 20, 2012 5:37 pm
In your case take a look under Country selection, try to set it on No_Country_set) and take a look on Current Tx power tab.
But i have another weird problem. Recently bought R52Hn (Manual says "Output Power of up to 25dBm @ a/g/n Band") but mine runs Max 22dBm under 6Mbps. Country mode No_country_set, Tx power default, frequency 5180.
uldis
Sat Jan 21, 2012 11:50 am
most likely you have only one wireless chain enabled. Connect second antenna to second connector and enable chain1.
Chewers
Sat Jan 21, 2012 5:55 pm
Yes i use only one ANT57/PAR 5Ghz antenna. So 25dBm possible only with both chains enabled?
Users browsing this forum: bayerflyer and 100 guests
