MUM Europe 2020
Proton
Which antenna & RB for basestation?
Wed Feb 01, 2012 4:47 pm
I am setting up a 90° sector or 2 60° for about 50 customers.
I want a good speed as possible using Mikrotik RB & a sector antenna of some sort.
I will use Nv2
I am thinking of :
Ubiquity AirMax 5GHz Carrier Class Sector 2x2 MIMO Antennas 20dBi Hi-Gain Airmax Sector 5G-90-20
and this box:: http://www.balticnetworks.com/maxxwave- ... stems.html
Any problems ? Will Nv2 work with Ubiquity AirMax antenna?
Can i get much speed with LOS 2-6km?
I plan to use RBSTX: http://routerboard.com/RBSXT as clients
Goal is 20 Mb both directions to customers (max 2-4 active at the same time)
100Mb behind the base
krajnalic
Re: Which antenna & RB for basestation?
Sun Feb 19, 2012 1:55 am
50 users on a single AP is not a good idea, so better split it into 2 if you can. RBSXT is good if distance is max 2km, and you can make your 20mbit/20mbit. For longer distances you must use dish 2x2 MIMO antennas and RB711 dual chain model for example. This is from my experience. If I helped you a little dont forget to give me a karma :-)))
Users browsing this forum: No registered users and 28 guests
