mapunda
SXT-5HPnD
Thu Apr 05, 2012 4:04 pm
http://routerboard.com/RBSXT-5HPnD
Now we are moving.
Waiting for SEXTANT with the same output power ! :D
mahnet
Long time Member
Long time Member
Re: SXT-5HPnD
Thu Apr 05, 2012 4:09 pm
Now we are moving.
Mikrotik,
23dbi antenna and metallic enclosure please. Fedup with plastic. 16 dbi with that much power is a low requirement. High antenna gain is needed more. Sextant is a bit short.
mapunda
Re: SXT-5HPnD
Thu Apr 05, 2012 4:55 pm
This device is the best to work with omnitik. When should we expect to get from our distributors?
mahnet
Long time Member
Long time Member
Re: SXT-5HPnD
Thu Apr 05, 2012 5:31 pm
How is it best for ominitik?? compared to the usual SXT
DiabolixZA
Re: SXT-5HPnD
Thu Apr 05, 2012 7:14 pm
Now we are moving.
Mikrotik,
Agreed, higher gain antenna and lower beam-width is better than using more power to reach the distance you require. This will destroy a mast on default tx power, if used for a PTP link.
jadu
Re: SXT-5HPnD
Fri Apr 06, 2012 3:33 pm
I prefer narrower band then high power.
Curious to see how it performs though.
Don't give thanks, give karma instead!
roborkk
Re: SXT-5HPnD
Thu Apr 19, 2012 7:41 pm
Now we are moving.
Mikrotik,
Yes, I agree strong too. The best amplifier is good ANTENNA !!!
taduikis
SXT-5HPnD
Fri Apr 20, 2012 12:42 am
I don't see where this hp sxt would fit. Could someone give me a hint?
P2MP is out of question me think..
normis
Re: SXT-5HPnD
Fri Apr 20, 2012 8:19 am
Distributors should already have it! Email them and ask.
If not for PtM, then for short PtP links. 10Km should be possible.
admkrtp
Re: SXT-5HPnD
Fri Apr 20, 2012 12:27 pm
can I use this device as a Acces Point or as a Hot-Spot ?
normis
Re: SXT-5HPnD
Fri Apr 20, 2012 2:02 pm
You could, but it has a narrow beamwidth directional antenna, which is made for a different purpose. clients would all have to be facing the SXT unit directly.
For accesspoint and hotspot, I recommend a similar device, but with the appropriate type of antenna, the OmniTIK: http://routerboard.com/OMN5HnD
admkrtp
Re: SXT-5HPnD
Fri Apr 20, 2012 2:43 pm
Actually I already have this device as gift from my friend so I just want to know how can I use this device :)
pacoss
Re: SXT-5HPnD
Fri Apr 20, 2012 5:25 pm
I work in a saturated area, so I also prefer narrow beamwidth and metallic enclosure to minimize interferences.
Antenna dBi better than radio dBm!
winet
Re: SXT-5HPnD
Sat Apr 21, 2012 5:49 am
i prefer omnitik with higher power
helectro
Re: SXT-5HPnD
Sat May 12, 2012 5:25 am
Now we are moving.
Mikrotik,
+1
Users browsing this forum: No registered users and 22 guests
