MUM Europe 2020
syadnom
Omnitik in 2.4Ghz?
Sun Apr 08, 2012 8:44 am
I would love to see an omnitik in 2.4Ghz. I am currently using the 751u but I have industrial environments and the omnitik is a better fit (if it was 2.4Ghz). Also, I would love to have the omnitiks antennas over the 751u. High output power in the 751u is useless to me with such low gain antennas.
acim
Re: Omnitik in 2.4Ghz?
Sun Apr 08, 2012 5:03 pm
Me too :wink:
normis
Tue Apr 10, 2012 9:22 am
one chain you can replace with much larger gain antenna, as the device has a MMCX connector.
syadnom
Tue Apr 10, 2012 4:43 pm
Thanks normis. The outdoor enclosure of the omnitik is also highly desirable.
normis
Wed Apr 11, 2012 8:30 am
What about the Groove then? Use any antenna, and it has an outdoor enclosure. It's also very small.
syadnom
Wed Apr 11, 2012 5:19 pm
the groove doesn't have a built in switch. I could use an omnitik 2.4Ghz as a soho router in my industrial environments with high gain dual polarity antennas.
I can put something together to do this but I would need a 493 + enclosure + wireless card + 2 antennas which is easily $238. Additionally, the OmniTIK is designed to mount to just about anything quickly and easily where a metal boxed 493 would be a little more effort and still wouldn't be as tough.
The OmniTIK 5Ghz is $89, so if a 2.4Ghz was similar the savings would be quite good.
I would also add that an OmniTIK is auto-WDS and HWMP+ in 2.4Ghz would make a nice little mesh node too.
happydaddy
Mon Apr 16, 2012 1:49 am
+1
I am using 5ghz ubiquity as backbone and mikrotik RB433 as hotspot and routing. Save me efforts of making up a routerboard wirelesscards, lmr cable, antennas etc.
Please make a 2.4 if possible.
cristianogoulart
Wed Feb 06, 2013 10:48 am
Brazil also requests a Omnitik at 2.4Ghz.
The two antennas may have 10dBi or 12dBi.
Would be a great product!
osvaldotcf
Thu Feb 07, 2013 10:21 am
With 8 dbi would be great.
It would be a great competitor for the Ubiquiti Unifi.
petercolt
Tue Feb 12, 2013 4:25 pm
And it may easily win the competition, actually
Users browsing this forum: No registered users and 10 guests
