honzam
New 711 - metal ethernet
Fri Jun 01, 2012 9:45 am
Can MT team confirm that new 711 have metal ethernet port?
Cheers!
LAN, FTTx, Wireless. ISP operator
normis
Re: New 711 - metal ethernet
Fri Jun 01, 2012 9:57 am
Yes, we listened to your suggestions, and improved the connector in new revisions.
taduikis
Fri Jun 01, 2012 10:02 am
Horray! Too bad last shipment of ours doesn't contain revised boards :(
normis
Fri Jun 01, 2012 10:03 am
We are slowly transitioning to the new part, so you will not see this immediately in all new shipments.
Also notice that the port is no longer upside down - easier to unplug
honzam
Fri Jun 01, 2012 10:46 am
Good to hear from you!!! Thanks !!! :)
I hope that it is on always. :)
Normis and which models? Only 711xx or also 433, sxt?
noyo
Sat Jun 02, 2012 9:31 am
What about shields? Next there is the problem?
MyThoughts
Sat Jun 02, 2012 6:05 pm
Does the ground plane of the new board revision now connect to the ethernet shield, like it did on the RB1xx,3xx,4xx,5xx,6xx,8xx series boards?
normis
Mon Jun 04, 2012 8:36 am
Ground plane has always been connected to the ethernet port, including on the plastic connectors of the RB711 previous revision and RB411L etc. The grounding pins are inside the connector, and they connect to PCB ground: http://wiki.mikrotik.com/wiki/Grounding ... RD_devices
So all ethernet ports can be connected to shielded cables - both metal or plastic.
NathanA
Forum Veteran
Forum Veteran
Mon Jun 04, 2012 11:32 am
Ground plane has always been connected to the ethernet port, including on the plastic connectors of the RB711 previous revision and RB411L etc. [...] So all ethernet ports can be connected to shielded cables - both metal or plastic.
That's what I thought...if you look inside the plastic connector, you can clearly see the metal grounding tabs at the base of it. So I never understood the complaints about the plastic connector.
But the fact that it is reversed for easier access to the tab on the RJ45 connector is definitely good news. :)
-- Nathan
MyThoughts
Mon Jun 04, 2012 6:06 pm
@NathanA I thought the exact same way as you till I actually checked continuity from our enclosure to those little metal clips in the plastic ethernet connector.
On the RB4xx series boards if I install the board in a metal enclosure with metal standoffs, I can use a continuity meter and see that the shield on the ethernet connector makes good connection with the metal enclosure, the radio card, and anything else that needs a ground.
This means that through the ethernet connector everything that matters (box, radio, board, etc.) all have a decent ground, with no ground loops.
If I do the same test on the box of RB711G-5HnD boards I have, I see no continuity at all from the little metal clips in the plastic ethernet to anything else. This is the reason I stopped using the RB711 series boards, it wasn't the plastic connectors that were my issue.
taduikis
Mon Jun 04, 2012 7:23 pm
I believe that plastic sockets was inpopular not because of the grounding issues, but for their poor mechanical strength. These metalic sockets are almost indestructable compared to those plastic ones. At least I haven't had any problems with them compared to plastic.
Did you try to check continuity between inner ground pin of the rj45 and screw hole?
gcs
Mon Jun 04, 2012 10:12 pm
I THANK YOU! The plactic Ethernet were too weak. Any strain would pull the socket off the motherboard. I hope the RB411-L are fixed too.
cbrown
Trainer
Trainer
Mon Jun 04, 2012 11:55 pm
I finally broke a plastic one trying to get the damn thing unplugged. It is really good to hear Mikrotik has made them metal again and flipped them over. I think the flip is just as important if not more important than it being metal.
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
rzirzi
Tue Jun 05, 2012 2:39 pm
Thank You. It's very good news! :) We hope that You will change all plastic ports on new boards to metal one.
MyThoughts
Tue Jun 05, 2012 5:03 pm
I am assuming you are talking about small metal ground clips on the inside of the plastic connector. If so, then yes that is where we checked continuity from, but it was hard to take a picture. The clips on the inside are part of the metal that is soldered to the PCB (where I am checking from in the picutre), and continuity is good from the solder to the clips on the inside so it doesn't matter. We also checked the RB711 from the ethernet ground to the metal radio shield and we also get no continuity.
I know many people had issue with the connectors falling apart but we have good stain relief on our cables and we were not putting any force on the connector, but the ground issue is was prompted us from discontinuing the boards use.
Of additional note, we have recieved our first batch of RB433GL boards with the plastic ethernet, and they do not exhibit this issue. Despite the plastic ethernet connector, the ethernet shield pins connect to the PCB ground plane properly.
Maybe this is an early revision, or a bad batch of RB711 boards?
Cheers
honzam
Wed Jun 20, 2012 11:08 am
Hello.
What types of routerboard will have metal ETH?
miahac
Long time Member
Long time Member
Tue Dec 04, 2012 1:41 am
THANKS
Does it have a plastic rivet through the pcb too?
Network Consultant in Wichita, KS
miahac
Long time Member
Long time Member
Tue Dec 04, 2012 1:44 am
BTW, i just found this thread and have bought at least two with the old connector since September (maybe more but they did not break), seems some are still in the channel.
Neilson
Thu Dec 06, 2012 11:08 pm
Can anyone who has received any 711 boards of any version with metal ports please tell us which device and which batch code (three digits after the slash in serial number) they came from.
My supplier has Sextant G (711G board inside) batch code 220 (batch code on the sextant not the board inside) that are still with Plastic ethernet ports.
I am just trying to get an idea about what batch codes people are seeing and when the metal ports are appearing.
Regards
Alexander
normis
Fri Dec 07, 2012 7:59 am
Only if you purchase RB711 separately, will you get a high chance to receive a metallic port. SEXTANT is a slightly different matter. They are not as popular as bare RB711 devices, so transition to new port is much slower.
Users browsing this forum: No registered users and 18 guests
