MUM Europe 2020
raska
Kernel not found after upgrade
Thu Jan 12, 2006 1:03 pm
After upgrade Mikrotik on "RouterBoardu 500 Series" from version 2.9.5 to 2.9.10 and afret reboot I got message "kernel not found"
help me pleas
V. R.
RouterBOOT booter 1.0beta2
RouterBoard 532
CPU frequency: 266 MHz
Memory size: 32 MB
Press any key within 1 seconds to enter setup.
kernel not found
RouterBoard 532
Memory size: 32 MB
Art
Thu Jan 12, 2006 3:41 pm
raska
Tue Jan 24, 2006 3:05 pm
Using netinstall
ON WINDOWS 2k3 - netinstall
RouterBoard 532
Memory size: 32 MB
Press any key within 3 seconds to enter setup...
trying bootp protocol... OK
Got IP address: 10.0.0.222
resolved mac address 00:0F:EA:64:A2:1F
transfer started .................. transfer ok, time=1.2s
loading program into address 0x80293370, size 0x00000018 0x70000000
loading program into address 0x80101000, size 0x001D3000 0x00000001
done setting up elf image
kernel entry point is 0x8027A040
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:04:03:12
software-id: F0FC-3TT key:
Lr4KHTD4aWs9AbWQO15gdl29jqL063HlSDCbuZX3jOGtgRJqLfeuNBRBnRZKrevseHUwtpN7okpdm69T
AFE14B==
Waiting for installation server...
Found server at 00:50:56:C0:00:08
Formatting disk.........
ERROR: installation of routeros-rb500-2.9.11 failed: disk is too small
WARNING: package system-2.9.11 onuninstall script failed
Press ENTER to reboot
on Windows XP - netinstall
Lr4KHTD4aWs9AbWQO15gdl29jqL063HlSDCbuZX3jOGtgRJqLfeuNBRBnRZKrevseHUwtpN7okpdm69TAFE14B==
Found server at 00:00:E2:94:8E:96
FATAL ERROR: bad network connection
djape
Tue Jan 24, 2006 4:03 pm
Out of subject
@raska where are you from mate?
I drink like a pirate and smoke like a hippie...
tneumann
Wed Mar 01, 2006 8:09 pm
I was in the exact same situation just yesterday. You can fix
this by updating the RouterBoard BIOS to version 1.7 and
use its new "Format NAND" BIOS menu option.
On the re-formatted NAND the netinstall will probably work OK.
crosaire3
What utility/process to upgrade RB500 FW to 1.7...???
Fri Mar 10, 2006 8:47 pm
:?: :?: :?: :shock:
Frustrated..... Just trying to get my RB532 to boot.... stuck at the Starting Services.......
Figured I'd upgrade the FW..... but no relief there either.... see below..!!
Looking ALL over RB site and MT site to no avail.... WHAT UTILITY SHOULD BE USED TO UPGRADE THE FIRMWARE ON TEH RB500...???
I HAVE ATTEMPTED TO USED THE SERIAL FILE UPLOAD... BAD FILE ID
I HAVE ATTEMPTED TO USE A BOOTP SERVER.... BAD FILE ID
I HAVE ATTEMPTED TO USE THE RB200 1.3.6 UPGRADE UTIL... BAD FILE ID
Ok....... so what's the secret and why is a secret...???
crosaire
crosaire@iguananet.com
tneumann
Re: What utility/process to upgrade RB500 FW to 1.7...???
Sat Mar 11, 2006 6:01 pm
You can upload the firmware via the serial console using Xmodem protocol (for ex. with Hyperterm from Windows).
It's also explained in the Wiki.
Worked for me, no issues with BAD FILE ID or anything like that.
dzelde
still - kernel not found
Sat Apr 15, 2006 7:55 pm
I have the same problem. did the netinstall completed without problems. But RB still wont boos saying: kernel not found !
How to install kernel?
dzelde
now ok
Sat Apr 15, 2006 11:50 pm
after upgrading bios from 1.4 to 1.11, system booted normaly.
only after adding few wds, system seemed to hang up, and come back only after power restart :(
csickles
Sun Apr 16, 2006 8:35 am
This is going to sound "STUPID" but....
I have one of the original RB500s.
I almost sent the board back for this sale issue (I had an RMA and all)
Here it comes......
Use Dumb / Stupid /Slow NICs when running netinstall to a routerboard 5XX
I had a Compaq laptop connected to my RB500 and used Netinstall to upgrade the OS.. it CRASHED with the same issues...
I tried and tried to correct it... I tried cables, options witih the boot sequence and all..
I finaly tried an old 3Com PCMCIA card to run NEtInstall from and it WORKED !!
There seems to be a point durring the reload wher the routerboard will drop the ethernet conection for a split second. If your card is a fast one it will pick this up and freak, causing Netinstall so sense a network failure and the reload will abort..
Usa a Old / Stupid / Slow NIC and it does not "cacth" the drop... and the reload works..
I now ALLWAYS carry an OLD 3Com or Xircom PCMCIA card in me laptop case just incase my RB500 needs a "Fresh Brain"...
Good luck and good "RouterBoarding"
Craig
Things that make you go "Hmmmmmmmm"...
Craig
GotNet
Sun Apr 16, 2006 5:26 pm
I'll second what Craig said. I solved it a different way by using a switch between the install pc and the board. The nic on the pc doesn't see the 'drop'.
Mike
Fabbbio
Tue Jun 27, 2006 2:04 am
DAMN Kernel not found
I try netinstall on win xp but everything remain blank and I can't see MAC of my rb532
In rb532 bios I put boot from eth...protocol bootp
I connect rb532 and my pc to a switch .
On my pc i set ip to 172.16.0.10 (like in doc)
and in netinstall .....5
but nothing:
RouterBoard 532A
CPU frequency: 264 MHz
Memory size: 64 MB
Press any key within 5 seconds to enter setup.....
kernel not found
trying bootp protocol...........................................................
................................................................ failed
kernel loading failed
I try with a linksys wrt54g as switch and dhco server enable , boot protocol dhcp with the same result.
sergejs
Tue Jun 27, 2006 7:08 am
Fabbbio, have you tried this netinstall ?
Fabbbio
Tue Jun 27, 2006 11:28 am
Yes...I use it . Nothing to do!
Somewhere I read to put ms*****.dll in the same directory of netinstall, but I don't know if it is necessary and where I can find this DLL.
Art
Fri Jun 30, 2006 7:28 am
if you use standard built in ethernet card on pc with winxp, try to connect with
pci ethernet card, I had this same problem and i used other pci card and net install worked good
try it
normis
Fri Jun 30, 2006 10:51 am
a solution is to first plug in the ethernet cable and then start router, and then start netinstall (in this sequence). this depends on the windows network card, can you tell us which network cards do you use (users who have this problem)?
Fabbbio
Sun Jul 02, 2006 12:15 am
OK I try..
I used my notebook but now I can try with a desktop pc.
Fabbbio
Sun Jul 02, 2006 1:46 pm
I try with my old pc (Pentum II) with a ISA eth and win xp , netinst not work
Tomorrow I try with another pc.
With serial upgrade and all in 1 pack file I get "invalid upgrade file id
Users browsing this forum: No registered users and 22 guests
