tombee79
Can i fit and run three Dbii DB-F50-PRO to 733AH or 733?
Thu Jul 19, 2012 8:07 am
Hi
Will i be able to fit all of the three? if yes what frequency should they run on, to dont cause interference?
Thx
mahnet
Long time Member
Long time Member
Re: Can i fit and run three Dbii DB-F50-PRO to 733AH or 733?
Fri Jul 20, 2012 5:33 am
733?? Not seen this product yet.
tombee79
Fri Jul 20, 2012 7:59 am
check routerboard.com
honzam
Fri Jul 20, 2012 9:06 am
733 is not real product. Only 433 and 433AH
LAN, FTTx, Wireless. ISP operator
mahnet
Long time Member
Long time Member
Fri Jul 20, 2012 6:51 pm
hahaha...
and this guy made me search routerboard.com so many times.
tombee79
Sat Jul 21, 2012 6:59 am
Appology, i must be long day. lol
you right man it is 433 or 433AH
tnakir
Mon Aug 13, 2012 12:24 pm
Nope, you can not fit 3 of those cards into RB433 cause they're too thick.
n21roadie
Mon Aug 13, 2012 1:12 pm
Even if the radio cards would fit, it is bad practice to use 3 cards onto one routerboard as there will be self interference as throughtput increases on the radio cards also if the board goes down it takes down whatever the radio cards are connected to.
N21roadie,
Network 100% MT for Now?
Users browsing this forum: doush, grusu and 35 guests
