Hopefully someone can help me.
I have a RB433 and after rebooting the RB, it didn't work - I connected a Serial cable (USB to RS232 Converter) with a Null Modem cable and was able to connect via Hyperterminal into the RB. The RB just reboots the whole time. Here is what it says:
RouterBOOT booter 2.29
RouterBoard 433
Authorization: Passed
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
PHY ERROR
trying bootp protocol.......
RouterBoard 433
Memory size: 64 MB
PHY ERROR
Another important item to note is that with a LAN cable connected from ETH1 to my Laptop it does not seem to connect at all, and no lights come on from the RB side. Hopfully there is some way fix this problem, if I can get into the RB with NetInstall I should not have problems installing the required software again.. It is as if the Ethernet ports are blocked or disabled.
Any Help Please...
