steven99
How to force DNS requests using tcp protocol!
Mon Dec 17, 2012 6:18 am
Hello
I set /ip dns server = 8.8.8.8, The RB751 default using udp protocol and Google DNS session.
But udp/53 in China have been contaminated, the ip address returned is false.
We test tcp/53 request to Google DNS query, the results returned are correct.
But how to force the RB751 to use tcp protocol and Google DNS session it?
Thanks!
Dobby
Re: How to force DNS requests using tcp protocol!
Mon Dec 17, 2012 8:20 am
Deleted because not related.
steven99
Mon Dec 17, 2012 8:36 am
Hello steven99,
did you not got another one from your ISP?
Hello Dobby
My ISP has a DNS server, but that is contaminated dns server.
If use isp's dns, often get false results, they prohibit access to certain foreign sites.
Now I did not find the way how to force the RB751 tcp protocol and Google DNS session.
Steven
TheWiFiGuy
Mon Dec 17, 2012 8:42 am
Is your isp not doing a nat redirect to force you to use theirs despite your settongs?
steven99
Mon Dec 17, 2012 9:10 am
Hi TheWiFiGuy
Dns server can freely choose.
But network operators monitoring / interference port 53/udp, if you visit a site that they do not want, you get the ip address is false.
If to use port53/tcp and Google DNS seems everything is normal.
Steven
Dobby
Mon Dec 17, 2012 9:17 am
uksv29
Wed Dec 19, 2012 8:16 am
I don't think you can force requests to be TCP in a Mikrotik router.
I can think of a couple of ways to sort your issue,
1. Run your own DNS resolver on a Linux box - you could even try metarouter. You may be able to force Bind9 to use TCP requests.
or
2. Find a friendly server not too distant from China (latency) and open a VPN tunnel to it then use the tunnel to access the Google DNS 8.8.8.8 etc. Add /32 routes to your Mikrotik pointing to the PPTP/SSTP/IPSEC tunnel for 8.8.8.8 and other server IP addresses.
regards
Andy
steven99
Wed Dec 19, 2012 11:05 am
or
regards
Andy
Hi Andy / uksy29
Thank you for the suggestion!
Now I have to use the first program to use dnsforwarder (Chinese programmers write software), mandatory use tcp protocol to resolve.
The second program I originally used, but the low efficiency of this method after vpn, slower.
Originally, I was hoping to solve this problem directly RB751, but now it seems impossible.
Steven
19.DEC
Users browsing this forum: No registered users and 89 guests
