honzam
Bad capacitors on rb1000
Mon Dec 17, 2012 7:31 pm
RB1000 works, but randomly hangs. No diodes light. Power off, on - it help.
After openning case - capacitor are leaked.
It is know problem on rb450/450G and another models...
It is sad that the Mikrotik flagship is mounted such capacitors :(
LAN, FTTx, Wireless. ISP operator
Dobby
Re: Bad capacitors on rb1000
Mon Dec 17, 2012 11:41 pm
Deleted because not related.
janisk
Wed Dec 19, 2012 3:05 pm
all caps have lifetime, how long this router was on?
chojrak11
Wed Dec 19, 2012 4:52 pm
I had some of those, too... It's a real plague in the industry. https://en.wikipedia.org/wiki/Capacitor_plague
Conductive polymer aluminum solid capacitors are also shown on this page :-)
Dobby
Wed Dec 19, 2012 6:16 pm
honzam
Wed Dec 19, 2012 7:21 pm
Hello honzam,
I would prefer to find some conductive polymer aluminum solid capacitors over the Internet.
They cost is much higher then the cheaper ones, but also the lifetime of those and your RB1000 is gaining up!!!!
Hello. I know these capacitors. We will soldering - rb1000 again come alive :)
I'll try to find out and write ...
edit: Can you find out from the serial number? It would be faster
ohara
Thu Dec 20, 2012 9:16 am
For somebody who is not familiar with capacitors like me, could you advise what type of polymer caps I should be looking for to replace bulged suscon 6.3V 560uf? Do I search for 6.3V 680uf polymer caps?
janisk
Thu Dec 20, 2012 9:35 am
from S/N i can only tell when it was manufactured. And that is about 4 years ago.
KillerOPS
Sat Sep 16, 2017 9:14 pm
Another rb1000 with bad caps. Same caps. It was working for a few years pretty well, until after a power loss the lan ports wouldn't come back up (although the device booted successfully). Quickly replaced with a rb750gr3, and opened it up to see what's happening, as I was suspecting some caps.
Of course, those 560uF caps were all leaked. Replaced them with 1500uF 10V and it works well.
If it's still open, I was wondering what JP6 and JP5 are for. Any hints?
Users browsing this forum: No registered users and 26 guests
