MUM Europe 2020
ak1001
RB751G-2HnD switch ports down and up
Wed Jan 23, 2013 11:44 pm
Hi, just bought RB751G-2HnD to is as home router
Firmware 3.0, upgraded to RoutersOS 5.22
Setup WAN port 1 - dhcp, pptp
LAN - port 3 - home computer
LAN - port 5 - smart TV
Router contiouniusly switch me off and on.
Logs show:
86 Jan/23/2013 20:11:07 memory interface, info ether3-slave-local link down
87 Jan/23/2013 20:11:08 memory interface, info ether2-master-local link down
88 Jan/23/2013 20:11:10 memory interface, info ether3-slave-local link up (speed 1000M, full duplex)
89 Jan/23/2013 20:11:11 memory interface, info ether2-master-local link up (speed 10M, half duplex)
90 Jan/23/2013 21:06:57 memory interface, info ether3-slave-local link down
91 Jan/23/2013 21:06:58 memory interface, info ether2-master-local link down
92 Jan/23/2013 21:07:00 memory interface, info ether3-slave-local link up (speed 1000M, full duplex)
93 Jan/23/2013 21:07:01 memory interface, info ether2-master-local link up (speed 10M, half duplex)
94 Jan/23/2013 22:04:58 memory interface, info ether3-slave-local link down
95 Jan/23/2013 22:04:59 memory interface, info ether2-master-local link down
96 Jan/23/2013 22:05:01 memory interface, info ether3-slave-local link up (speed 1000M, full duplex)
97 Jan/23/2013 22:05:02 memory interface, info ether2-master-local link up (speed 10M, half duplex)
any tips what going on?
sb1mpo
Re: RB751G-2HnD switch ports down and up
Thu Jan 24, 2013 10:49 am
Try turning auto-negotiate off and then set the link speeds manually, if the manual link speeds you have set still fail then try a different speed + duplex.
I have seen this a few times with other vendors...
Hope this helps
BSc(Hons), MTCRE, MTCWE, MTCNA, CCNA, CCENT, ZCNE Security
ak1001
Thu Jan 24, 2013 6:02 pm
thanks for suggestion
computer link was 1G
First i logged into winbox, into interfaces and uncheked Auto Negotiation checkbox in ether3-slave-local properties, speed radio was at 100 Mbps
Then clicked buttun Apply and immediately lost connection to router. Lost dhcp ip, Winbox don't see it, and even with manually assigned ip to computer, no ping.
Then i switched computer cable from router port 3 to port 2 and connection restored on ether2-master-local again 1G, all working.
After that i switched speed at computer side to 100 Mbps full duplex, all working good.
Very strange behevoir.
Will se how it will work at 100 Mbps
Support responded with suggestion to check cable. Will try this tomorrow with simple cable tester.
ak1001
Mon Jan 28, 2013 4:00 pm
No up/down since i set speed to 100 mbps on computer side. working stable.
BrainWaveCC
Mon Jan 28, 2013 9:55 pm
Is the NIC on your computer a 1Gbps NIC or a 100Mbps NIC?
Users browsing this forum: CZFan, MSN [Bot] and 33 guests
