FutileNetworks
sfp module not detected on RB2011UAS-RM
Thu Feb 07, 2013 4:16 am
As subject, purchased 2 SFP modules from mikrotik distributor, neither work in 2011UAS-RM using 5.23 and 6.0rc9, but they are detected in our CCR1036-12G-4S, from the CCR:
[admin@MikroTik] > /interface ethernet monitor sfp3
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
sfp-module-present: yes
sfp-rx-lose: no
sfp-tx-fault: no
sfp-connector-type: LC
sfp-link-length-50um: 550m
sfp-link-length-62um: 270m
sfp-vendor-name: OEM
sfp-vendor-part-number: GLC-SX-MM-C
sfp-vendor-revision: A1
sfp-vendor-serial: TC1412180046
sfp-manufacturing-date: 12-12-18
sfp-wavelength: 850nm
Also tried another sfp module which also works in CCR but not in 2011UAS-RM
sfp-vendor-name: EDIMAX
sfp-vendor-part-number: MG-1000AMA
sfp-vendor-revision: 0000
sfp-vendor-serial: C416011856
How do I get these working?
roc-noc.com
Forum Veteran
Forum Veteran
Re: sfp module not detected on RB2011UAS-RM
Thu Feb 07, 2013 4:43 am
I would think you should work this through your distributor. They should be selling and supporting compatible modules if they are selling both RouterBoards and SFPs.
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
Dobby
Thu Feb 07, 2013 6:16 pm
Deleted because not related.
FutileNetworks
Fri Feb 08, 2013 10:01 pm
Turns out these modules work fine, the problem was auto negotiation on the CCR defaults to off and needed to be turned on (thanks Chaos @ linitx).
nest
Forum Veteran
Forum Veteran
Wed Mar 20, 2013 4:30 pm
This has been acknowledged by MT as something that will be fixed in the next release.
Ron Touw - Mikrotik Certified Consultant and Trainer
Freeclix.com
gilito
Sun Feb 07, 2021 2:24 pm
Hi!
The same with 35LC20D and 53LC20D pair.
I tested with an RJ45 SFP and port works. So I think is about firm/soft issue
On RB3011 I can se module present, led on and how version an tx/rx power
On Rb2011 unable to see nothing
Routerboard info
/system routerboard> print
                ;;; Firmware upgraded successfully, please reboot for changes to take effect!
       routerboard: yes
             model: 2011UAS
     serial-number: 374802D1AEF8
     firmware-type: ar9344
  factory-firmware: 3.0rc5
  current-firmware: 6.45.3
  upgrade-firmware: 6.48
SFP monitor
/interface ethernet> monitor sfp1
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
               sfp-rx-loss: yes
                  sfp-type: (unknown)
           eeprom-checksum: good
                    eeprom: 0000: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0010: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0020: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0030: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00a0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00c0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00e0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
Resources info
/interface ethernet> /system resource print
                   uptime: 1w5h1m1s
                  version: 6.48 (stable)
               build-time: Dec/22/2020 11:20:49
              free-memory: 92.5MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 10%
           free-hdd-space: 104.3MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 678175
         write-sect-total: 70360738
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB2011UAS
                 platform: MikroTik
If needed more info or screnshots, I can do!
quackyo
Mon Feb 08, 2021 10:20 am
Your 2011 might actually be too old.
I had a really old 2011 at a time that didn't take my SFP's. Support said that there was some revisions of the board, and that the really old ones didnt work correctly with some or all SFP's.
Users browsing this forum: mod3m and 38 guests
