sguox
Trainer
Trainer
Serial Console for RB2011
Thu Feb 07, 2013 6:41 pm
Any idea what's the correct settings using putty to connect to RB2011 serial port?
I notice the default baud rate configuration in the router is "auto". I changed it to 57600 and managed to connect to it only AFTER it boot up. When booting, it still showing garbage code.
w0lt
Re: Serial Console for RB2011
Thu Feb 07, 2013 6:58 pm
  • Auto should work fine.
    I have mine set to 115200.
    Make sure you have the correct cable (blue Cisco console cable is ok).
    Make sure you have the correct comm port selected on your pc.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
sguox
Trainer
Trainer
Fri Feb 08, 2013 9:57 am
thanks w0lt, so it's not auto after all, it's 115200 :)
Users browsing this forum: No registered users and 5 guests
