MUM Europe 2020
macsrwe
Forum Veteran
Forum Veteran
Suggest directional antenna for RB751?
Fri Feb 15, 2013 2:52 am
Client has a home router but also wants to serve a workshop just outside her router's range. I was thinking of just replacing the router with an RB751 and hooking up a directional antenna to the external MMCX jack.
I'm asking to see what particular model antenna people like and have used in the past for this purpose -- a modest SOHO directional antenna, hopefully with a compatible connector.
Thanks.
cbrown
Trainer
Trainer
Re: Suggest directional antenna for RB751?
Fri Feb 15, 2013 2:18 pm
If you are stuck on using the directional antenna I would just use an SXTG-2HnD. But you might be better off setting up a pair of 751Gs and making one a repeater and setting it in her shop. Without seeing everything or knowing more about the layout it is hard to tell.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
MacLean
Sun Feb 17, 2013 12:13 pm
We use these all the time with 433AHs and R52s.
http://www.streakwave.com/itemdesc.asp? ... 19&eq=&Tp=
-Mac
Sergio72
Thu Feb 28, 2013 12:42 am
Check this out http://www.wireless-instruments.com/en/ ... -5-20.html
I have used dual polarity antennas from WiBOX, but I have have spoken with WISPs who used single polarity.
Nice design.
macsrwe
Forum Veteran
Forum Veteran
Thu Feb 28, 2013 1:07 am
The WiBOX looks very nice, but is a router enclosure, plus it doesn't seem to be available in the US. I was looking for something more on the order of a dumb directional antenna capable of plugging into the provided MMCX jack in the RB751. In other words, this level of product:
As it turns out, after viewing this client's physical layout, the distance and layout requirement is more demanding than I expected, so I'm going to go with StationTik box at the remote site containing an RB411 PTP unit plus an additional radio card to run a small local omni. Thanks for your help.
Users browsing this forum: No registered users and 25 guests
