nelson6069
is CCR1016-12G able to handle this?
Mon Mar 04, 2013 4:59 pm
the environment is hostel. so i have max 400 concurrent users.
i will using this router to do this jobs:
1)Load balancing with 4 X 20Mbps(Download/upload)-dynamic ip address from ISP
2)NAT
3)Qos
4)Hotspot authentication with limited time (all wireless access)
5)DHCP server
6)Equal bandwidth base on active users.
7)remote access
or any recommendation?
shahbazian
Trainer
Trainer
Re: is CCR1016-12G able to handle this?
Tue Mar 05, 2013 12:21 am
I think this is the router for you.
Because we've done some similar projects and the amount of load is somewhat less than that, We don't had problems with this router and the RB1100AHx2 been responsive.
But I think to ensure more and the ability to upgrade in the future better use of the CCR1036-12G-4S.
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
nelson6069
Tue Mar 05, 2013 7:49 pm
so you think 1pcs of router is enough or need split into 2?
if split into 2:
1st router jobs
2)NAT
3)DHCP server
4)remote access
2nd router jobs
1)Equal bandwidth base on active users.
2)Qos
3)Hotspot authentication with limited time (all wireless access)
may i know which will use more CPU?
Dobby
Sat Mar 09, 2013 9:10 pm
Deleted because not related.
beta2000
Sat Mar 09, 2013 10:00 pm
Hi Nelson,
I think CCR series is better than RB series in your case. Here is an example which with 5x20Mbps load balance, policy route, about 100 users, hotspot and qos. It's using x86 version ROS with an Intel E2140 1.6GHz x2 and 512MB RAM.
shahbazian
Trainer
Trainer
Sat Feb 15, 2014 8:21 pm
Hi nelson6069
I think if you use CCR1036, You can use all config in one router. You may even use CCR1016.
So I recommend CCR136 for that
RIPE NCC Trainer
Kreacher
Fri Feb 28, 2014 8:44 am
Hello nelson6069,
Are they all at the same time online I suggest you also to take a bigger one
or you have the time to wait until all cores are smooth working on ROS
it would be the router for you I think, but the CCR1036 would be a better choice for you
Pretty sure it will.
2)NAT
Yes it will if you setting up a netfilter rule first and then a second one that tells
all other rules using the netfilter rule first, you also have SPI in the game! ;-)
3)Qos
If massively QoS rules will be used the entire router performance
can be really narrowed down, but this is also pending on the multi core
usage that is not really running now, as I see it.
5)DHCP server
7)remote access
No problem I think.
Kindly regards
Kreacher ♬
Karma points must not be paid by you
Users browsing this forum: No registered users and 11 guests
