1929
Mikrotik Metal 2.4 wihtout wireless
Mon Apr 29, 2013 3:22 am
I have metal mikrotik 2.4. It stops transmitting the wireless when it wants. No more setting to change. I've tried them all and the problem continues.
The SSID of the Metal mikrotik 2.4 disappears in a site survey.
Clients lose the connection in hotspot and have to restart the metal 2.4.
Sometimes I can restart remote, but others I have to go there and cut the power. I use it on battery because I was thinking that the original source was faulty.
I've tried all settings. I reduced the power, I used default power, I changed ack, I left only B mode B / G mode and B / G / N
It is one day, two, three or more days good. But at other times it hangs two or three times a day.
It stops transmitting the wireless when ithe wants. No more setting to change. I've tried them all and the problem continues.
Through experience I have with other RBs mikrotik I can say that I am not doing anything wrong. The conclusion that I have is that it has a design defect or batch production ou firwmare problem.
I saw that in registration Metal 2.4 clients do not disconnect.
But they will disconnecting in the hotspot.
Anyone else have encountered this kind of problem?
jandafields
Re: Mikrotik Metal 2.4 wihtout wireless
Mon Apr 29, 2013 6:52 am
What version and firmware are you using?
1929
Mon Apr 29, 2013 3:31 pm
It is the version that came from the factory: Version 5:21
I have other metal 2.4 with this same version. Also the same happens, but not as often.
jagga
Trainer
Trainer
Sun Jun 16, 2013 8:02 am
I have the Same Problem with my metal version of router os is 5,21 ... i m going to upgrade it to 6.1 .. then see what happens
Ivoshiee
Sun Jun 16, 2013 11:25 am
Going to some new revision software is going to introduce you different set of issues, better go for the latest one of the same series - v5.25 and then up it from that, if needed.
jagga
Trainer
Trainer
Mon Jun 17, 2013 4:22 pm
@Ivoshiee you were right i have upgraded to 5.25 now it is working fine.. Thanks :) :D
Jetrider
Thu Sep 05, 2013 10:22 am
I had the same problem with two METALs (2.4 ones), v5.25. I had AP-bridge setup with one wds. Upgraded to 6.3, gonna see what happens.
MikroUser
Sat Sep 07, 2013 2:05 pm
I have this same problem. Radio sometimes turn's off. Try to run 5.25 6.2 and 6.3 fw!!! think that is not SW problem!
Mikrotik support please answer!!!
1 Year i have Bullet M2HP and there was no problems!
diablonet
Wed Sep 18, 2013 1:53 am
Hello, same happened to me, I bought 4 of these APs, 2 of them had the same problem, WIFI were unstable, it kinda worked for a while after a reboot, but still unstable, I have tried everything, I reached support, after several mails and weeks, they ask me to send them to RMA, dont waste your time, these devices are kinda defective (at least 2 of 4 on my case=50%), return them!
arnoldmikro
Sun Sep 22, 2013 4:36 pm
Same problem no radio after 3 days reboot then 12 hours
sw 6.4
Model Metal 2SHPn
Serial Number 4475024B3344
Current Firmware 3.09
Mac address changes on wifi
mac is D4:CA:6D:9D:94:77
on channel 6+10
insidder program also slows
D4:CA:6D:3D:50:00
FF:FF:D4:CA:6D:95
ON channel 6
MikroUser
Sun Oct 13, 2013 12:59 am
while (true) do={:local a [/in wi reg get number=0 last-activity]; :local b {[:pick $a +4]}; :if (b>=2) do={[/system reboot];};}
this script is the solution for wireless down.
run with sheduler every 2-3 minutes
khaled11
Tue Oct 15, 2013 11:57 pm
sorry this script not working when wireless freezing on my metal2shpn
:D
khaled11
Wed Oct 16, 2013 11:48 am
script not working
plz help
:D
MikroUser
Fri Nov 01, 2013 11:28 am
my metal burn out today(( speed was 40 mbps and board work with it 5-10 mins. after - all leads is off. metal newer come back again. RIP (
for good work of this board you must limit summary bandwidth to 5 mbps for all wireless clients (not for each).
script might be not work sometimes. nobody dnot know why.
i used this version of script ( without while cycle)
local a [/in wi reg get number=0 last-activity]; :local b {[:pick $a +4]}; :if (b>=2) do={[/system reboot;];}
it works for me.
GREG3f
Sat Jan 11, 2014 5:28 pm
I agree that running a script to monitor the Wireless Interface is a bandaid solution. However, why do these units fail? Mikrotik needs to address this issue. It's not acceptable to have products that need bandaids to make them work.
I have installed these units at 100' on towers and been forced to drive to location and repower them because the units wireless stopped and the monitoring scripts (bandaids) have jammed the unit to the point where I could not access them.
The specs and design of these units is amazing and when they are running correctly they are great units, but they need to be made stable in order to be useable.
If your car suddendly stopped running on the highway and you had to stop the car, turn the key off and then back on again in order to continue your trip, would you not expect the manufacturer to fix the car?
jackcheng
Wed Jan 15, 2014 10:38 am
FIFA 14 Coins kaufen
rzirzi
Mon Feb 10, 2014 7:29 pm
We have THE SAME PROBLEM with MikroTik Metal-2Hn.
Groove A (level4) with the same configuration and in the same place - works good.
What is wrong with that Metal-2Hn?!
skik009
Wed Feb 12, 2014 3:57 am
I have the same problem with MikroTik Metal-2Hn.
Groove A2hn with the same configuration and in the same place - works good.
Its signal quality is very bad, unstable. Customers are not connected continuously.
happynet
Wed Feb 12, 2014 4:07 am
rzirzi
Thu Feb 13, 2014 9:36 pm
We all have the same problems with MikroTik Metal 2,4GHz, but MikroTik...
...silence...
framer99
Fri Feb 14, 2014 7:53 am
I've got the wireless client count checking script mentioned in one of the metal2.4 threads running so we at least do not have long periods with no traffic, the reboots are quick. Theres 2 of those type reboots in the log below.
But as you can see there are two other reboot types that occur.... kernel issues, and i guess just watchdog reboots are the "without proper shutdown" ones.
we've tried it all, we can't find any relief. we are currently on 6.9 but we've seend this on every 5.x and 6.x version we've tried.
The most frustrating thing is that there is no information on what is actually going wrong, nothing in the logs, nothing in autosupout.rif etc. If someone were to hackinto the linux command prompt behind RouterOS on the devices you might be able to log some information on what is happening before the reboot occurs. You would think Mikrotik has done this already and has some information to report
The same thing is occuring with a second Metal2.4 plus a SXT 2.4Ghz running as a sector.
We have a RB450 running on the same power source, aggregating the ethernet from those 3 aps, and it never reboots or hangs.
It's a reboot party on our tower.
[root@localhost log]# grep boot metal2.log
Feb  1 14:53:47 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  2 19:36:24 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  4 00:15:07 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  4 00:15:07 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  4 08:57:54 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  4 08:57:54 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  4 18:22:46 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  4 18:22:46 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  5 07:20:05 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  5 07:20:05 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  5 21:09:23 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  5 21:09:23 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  6 18:35:31 10.4.9.52 metal2  still 0 associated clients, router reboot
Feb  6 18:36:23 10.4.9.52 metal2 router rebooted
Feb  7 21:49:33 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  7 21:49:33 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  7 23:22:01 10.4.9.52 metal2 router was rebooted without proper shutdown by
Feb  8 07:27:34 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  8 07:27:34 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  8 08:39:15 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  8 08:39:15 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  8 18:11:21 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  8 18:11:21 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb  9 18:42:00 10.4.9.52 metal2 System rebooted because of kernel failure
Feb  9 18:42:00 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb 10 14:18:25 10.4.9.52 metal2 System rebooted because of kernel failure
Feb 10 14:18:25 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb 11 12:03:18 10.4.9.52 metal2 System rebooted because of kernel failure
Feb 11 12:03:18 10.4.9.52 metal2 router was rebooted without proper shutdown
Feb 12 08:33:30 10.4.9.52 metal2  still 0 associated clients, router reboot
Feb 12 08:34:22 10.4.9.52 metal2 router rebooted
Feb 13 18:26:28 10.4.9.52 metal2 System rebooted because of kernel failure
Feb 13 18:26:28 10.4.9.52 metal2 router was rebooted without proper shutdown
rzirzi
Mon Feb 17, 2014 7:36 am
So, what is the MikroTik team official respond at this topic?
The fact is: MikroTik Metal 2,4GHz working as AP - disconnects radio clients.
The MikroTik Groove 2,4Ghz at he same place with the same config - working good.
Conclusion: all MikroTik Metal 2,4GHz have hardware problem that is VERY frustrating and makes it unusable as Access Point!
skik009
Mon Feb 17, 2014 12:44 pm
I am requesting to MikroTik for any real action.
framer99
Wed Feb 19, 2014 11:08 am
In addition to the reboot log I posted above, I'm noticing that the unit will set itself to the 250Mhz cpu speed setting. I assume it' sdoing this because of a failed boot or something simliar during a kernel failure/reboot and stepping down the freq.
I dont' know that i would have caught it except with RANcID runing each hour to pull the config and diff it against the previous retrieval. it shows up every few days like this:
  set enabled=yes mode=unicast primary-ntp=10.1.1.10 secondary-ntp=10.1.1.110
+ /system routerboard settings
+ set cpu-frequency=250MHz
  /system scheduler
UpRunTech
Sat Mar 01, 2014 3:32 am
I too had this problem with the 2.4GHz Metals stopping transmitting. I am told v6.10 has a fix in it for this problem. Try it out.
framer99
Fri Mar 07, 2014 3:14 am
i tried it a few days ago as you suggested. 2 Metal2.4s and an SXT, things are definitely improved to just under 1 reboot per day... better than it was but not quite what I'd like to see. I still see the 250Mhz CPU setting kicking in/out via my RANCID config backup change notifications
it seems now the main reason for reboots is the wireless client count reboot script.
Mar  1 21:07:22 10.4.9.52 metal2 router rebooted
Mar  1 23:52:30 10.4.9.52 metal2  still 0 associated clients, router reboot
Mar  1 15:53:22 10.4.9.52 metal2 router rebooted
Mar  2 14:29:30 10.4.9.52 metal2  still 0 associated clients, router reboot
Mar  2 14:30:22 10.4.9.52 metal2 router rebooted
Mar  3 18:18:40 10.4.9.52 metal2 System rebooted because of kernel failure
Mar  3 18:18:40 10.4.9.52 metal2 router was rebooted without proper shutdown
Mar  5 20:59:30 10.4.9.52 metal2  still 0 associated clients, router reboot
Mar  5 21:00:24 10.4.9.52 metal2 router rebooted
Mar  6 16:43:41 10.4.9.52 metal2 System rebooted because of kernel failure
Mar  6 16:43:41 10.4.9.52 metal2 router was rebooted without proper shutdown
skik009
Fri Mar 07, 2014 5:12 pm
I am in same problem.
parrini
Fri Mar 21, 2014 3:47 am
Same problem here, Metal 2.4, version 6.10, up to 3 wireless freezes per day, only reboot to bring back.
Users browsing this forum: nm75081 and 41 guests
