tomaskir
Trainer
Trainer
2011 power plug - thank you Mikrotik
Fri Jun 07, 2013 4:50 pm
We just got a new badge of 2011UAS-RM and Im happy to say they include the new power plug design.
Thank you Mikrotik, this is so much better!
Will the whole 2011 series switch to this power plug system, or just the RM models?
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
payday
Re: 2011 power plug - thank you Mikrotik
Fri Jun 07, 2013 5:24 pm
Great news!
It's funny that sometimes MikroTik needs some time to "invent" obviuos things. ;)
This change means that board design has changed also. I wonder what else is changed. What type of USB is in it?
honzam
Fri Jun 07, 2013 5:45 pm
Can you give us inside photo? Are there two jack? One inside and one on the photo?
LAN, FTTx, Wireless. ISP operator
tomaskir
Trainer
Trainer
Fri Jun 07, 2013 5:59 pm
Here are the photos.
No secondary connector inside. However, notice the mounting inside for a proper brick PSU.
Also, on the back, a hole for a power connector is pre-cut.
Front USB is a MicroUSB plug.
honzam
Fri Jun 07, 2013 8:23 pm
Thanks for images. I found old revision 2011. This old revision don´t have beeper?
tomaskir
Trainer
Trainer
Fri Jun 07, 2013 9:30 pm
I was pleasantly surprised when the board beeped at boot time, yes :)
Overall, I really like this new revision!
pcunite
Sat Jun 08, 2013 4:00 am
And now all solid capacitors too! Is there any fan headers? Also, how to get this new version? Is old stock all flushed out?
tomaskir
Trainer
Trainer
Sat Jun 08, 2013 7:07 pm
Actually, not all solid caps. 2 of the smaller caps are not solid caps. No fan headers.
Stock was sold out, this batch arived directly from Mikrotik yesterday.
payday
Mon Jun 10, 2013 12:22 am
Beeper! Yeah! :)
Anyone knows if the design of other boards has changed also? Does RB2011UAS-2HnD-IN have new power connector, too? And a beeper?! :)
Any hardware changelog?
frankie
Wed Jun 12, 2013 6:11 pm
There are also place for internal power supply and 2-pin header on board.
HaQs
Mon Jul 15, 2013 7:56 pm
It is a pity that it is not in the front.
But it is always better than before
tomaskir
Trainer
Trainer
Mon Jul 15, 2013 8:23 pm
Front would be BAD. This is a rack-mount, in the back is the proper placement.
Why would I want a power plug in the front in the rack...
jp
Long time Member
Long time Member
Tue Jul 16, 2013 4:33 pm
I like the change too. Thanks!
I received a batch of 2011rm's about a month ago with the changed power plug.
Users browsing this forum: jurma33, morf and 20 guests
