markom
RB 2011UAS-RM cpu problem, or not?
Tue Jun 11, 2013 12:59 pm
If I remove absolutely all configuration from router CPU Load is 8% constantly? I am not complaining because on maximum my router is 35-45% CPU usage but as I think, should be there 0 or 1% CPU usage?
tomaskir
Trainer
Trainer
Re: RB 2011UAS-RM cpu problem, or not?
Tue Jun 11, 2013 1:00 pm
Look at the profiler tool. You will see SPI consumes the 8% CPU.
That is the LCD Touchscreen. Turn it off, and the router will be at 0%.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
markom
Tue Jun 11, 2013 1:12 pm
Yes, You are right. LCD Touchscreen consume 8%.
TY
Users browsing this forum: No registered users and 17 guests
