poizzon
RB2011UAS-RM, LCD blinking
Fri Jun 21, 2013 1:02 pm
a problem :
blinking :
poi
normis
Re: RB2011UAS-RM, LCD blinking
Fri Jun 21, 2013 1:05 pm
open the case and see if the lcd connector is firmly attached
poizzon
Fri Jun 21, 2013 1:07 pm
when booting, it showing normaly, bottom line
poi
normis
Fri Jun 21, 2013 1:20 pm
still, it is recommended to check the connector.
if connector is OK, make sure you run the latest RouterOS version 6.1 and run the "/lcd recalibrate" command
becs
Fri Jun 21, 2013 1:24 pm
Try to upgrade the bootloader:
/system routerboard upgrade
/system reboot
poizzon
Fri Jun 21, 2013 2:04 pm
/system reboot
upgrade and connector's recheking didn't help
recalibrating didn't work, only white line is blinking
version is : MikroTik RouterOS 6.1 (c) 1999-2013
p.s.: after and of boot'ing, in right corner starting blinking, and after second, full line starting blinking..
poi
normis
Fri Jun 21, 2013 2:26 pm
please show me output of "/system routerboard print", also please tell me, which RouterOS version you had before upgrading to this one
poizzon
Fri Jun 21, 2013 2:35 pm
[admin@MikroTik] > /system routerboard print
routerboard: yes
model: 2011UAS
serial-number: 427102312***
current-firmware: 3.08
upgrade-firmware: 3.08
[admin@MikroTik] >
i' didn't make any upgrade's today..
p.s. except your's command's, befor it your's command's was same 3.08
poi
poizzon
Fri Jun 21, 2013 2:43 pm
p.s.s.: i didn't wan't reset configuration.. but time is money....
it seem's like software bug, reset help in this situation..
but after restoring configuration - same think happened again..
attaching supout.rif
poi
normis
Fri Jun 21, 2013 2:53 pm
Try to upload this file to the device, and run "/system routerboard upgrade"
poizzon
Fri Jun 21, 2013 3:09 pm
routerboard: yes
model: 2011UAS
current-firmware: 3.06
upgrade-firmware: 3.06
[admin@MikroTik] >
downgrade'ing didn't hellp
poi
normis
Fri Jun 21, 2013 3:23 pm
uninstalling LCD package will help. The LCD package is not for routertboard.
poizzon
Tue Jun 25, 2013 8:51 am
confirming - helped
poi
Users browsing this forum: No registered users and 24 guests
