unterums
PTP Link between RB433AH R52HN and Sextant
Tue Jun 25, 2013 1:47 pm
i have a PTP Link with LOS ~ 19km
Site A = RB433AH with a R52HN Card and a 23dBI 9°/9° Dual Pol MIMO Antenna.
Site B = Sextant Power Output = 26dbm
Both on 5 GHz and with nstream
Upload from Site A > B is ok = normaly 7-10 Mbit
Upload from Site B > A is not good normaly 5-7 Mbit
Site A:
Signal:
TX -71 / RX -73dBm
TX / RX Rate:
52Mbps / 18Mbps (but not stable)
TX/RX CCQ %:
68/70 (but not stable)
P Throughpunt:
24190
The Link is not stable (broke up to 20 times a day)
Should i use RB433AH with a R52HN Card and a 23dBI 9°/9° Dual Pol MIMO Antenna on both sites ?
Anyone an idea ?
BR Thomas
letabawireless
Re: PTP Link between RB433AH R52HN and Sextant
Wed Jun 26, 2013 9:57 pm
Best scenario is to always use the same cards / config both sides. Also, do a spectral history, to make sure the channel you use has no noise.
WirelessInstruments
Fri Jun 28, 2013 12:58 am
Try to rotate 90 deg 23 dBi dual-pol antenna, then check your link.
The problem can be caused by dual polarity antennas. All of the antennas which we have tested (also our antenna -> http://www.wireless-instruments.com/en/ ... -24hv.html) have one polarization weaker than the second one. This problem is present mainly in dual pol antennas 23-25 dBi (on PTFE laminate), but this problem is available also in 18 dBi SEXTANT antenna.
Here is few words about how to install dual pol antennas in point-to-point links (and the reason why there are differences between polarizations) -> http://www.wireless-instruments.com/en/ ... tions.html.
Antenna professionals, custom antennas for any application.
WiBOX antenna manufacturer.
Skype ID: wireless-instruments
roadrunner79
Fri Jun 28, 2013 11:20 pm
try to use nv2 protocol instead of nstreme and see if you still have disconnects.
Users browsing this forum: No registered users and 18 guests
