MUM Europe 2020
Niex
CCR 1036 Ethernet problems
Sat Sep 14, 2013 12:37 am
Hy guys i have a CCR1036 12G board router running ospf.
The ethernet ports that are in use, is going down to up and the ospf down.
Before CCR we have a 1100 ah x2, this problem never happen, but with the improve of the link the
1100ah have to be replaced because cpu is 99% all the time.
The CCR is running 6.2 version of routerOS and the CPU is 4% average.
I upload the backup of 1100 on the CCR.
First week of use we have no problems, when problem start after a reboot stays 2 or 3 days normal.
Sorry by my english, thanks in advance.
Evok
Re: CCR 1036 Ethernet problems
Sat Sep 14, 2013 12:53 pm
I have the same problem after 4 day uptime on CCR 1016 MK version 6.2. After reboot works OK.
Niex
Mon Sep 16, 2013 2:19 pm
Update the CCR to 6.4, problem still
adyb76
Trainer
Trainer
Fri Sep 20, 2013 1:59 pm
Same problem here...running ROS6.4 and Firmware 3.09 with both copper and fibre interfaces.
Niex
Sat Sep 21, 2013 2:28 am
Its a serious problem !!!
And there is no solution.
Where is the staff or engineers os MK ?
kurtkraut
Sat Sep 21, 2013 7:17 am
Niex, you are facing a problem called ethernet port flapping. Other users have already reported it in this forum. Seek for a popular thread regarding this subject, subscribe to it and also describe the symptoms you are facing as you did here.
Also is important to contact Mikrotik's support directly so they can keep track on how many customers are affected by this issue.
p2systems
Sun Sep 22, 2013 8:42 pm
Hi
We have the same problem. (6.2 is installed)
After we have deactivated SNMP the CCR is running for 31 days without any problems. :)
Do you have snmp enabled?
adyb76
Trainer
Trainer
Mon Sep 23, 2013 9:27 am
No - snmp has never been enabled on this particular device.
So it's not related to snmp. The port flapping does come and go - so far it's been 3 days since the last instance.
Ade
compctech
Thu Oct 03, 2013 8:11 pm
We are having the same issues. We had to swap back to our RB1200. Is there any update on this issue.
Thanks,
Sam L.
Regards,
Compctech
Niex
Thu Oct 03, 2013 8:30 pm
Running 6.4 problem solved
compctech
Thu Oct 03, 2013 9:33 pm
When we got the unit, 6.4 was the current version and had to upgrade from a 6.0rc which was the install when we got the unit.
Regards,
Compctech
ckgth
Tue Oct 08, 2013 10:00 am
6.4 with CCR 1036 12G 4S - ALL PORTS (incl. SFP) Port-Flapping still exists. ;-(
There is no electrical reason on sfp :-) both SFP's are MT-SFP's
honzam
Tue Oct 08, 2013 10:28 am
It is fixed in pre-release 6.5 ?
LAN, FTTx, Wireless. ISP operator
macgaiver
Tue Oct 08, 2013 2:20 pm
MT is asking to check if problem with all port flapping on CCR is gone when you disable /snmp
There was other topic where some of customers already reported that problem is gone as soon as you disable /snmp
You should try that.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
ckgth
Sun Oct 13, 2013 6:37 pm
no. SNMP is off.
i have enabled and disabled it.
Ethernet Ports flapping again.
regards
sergejs
Wed Oct 16, 2013 3:00 pm
Please redownload new pre-release v6.5 from MikroTik.com. If you are interested in the newest pre-release version and you do not have access to it, contact support (support@mikrotik.com) for it.
Users browsing this forum: Rikjaard and 10 guests
