jldunham
RB112 Invalid Hotspot
Mon Apr 10, 2006 11:54 pm
I have been trying to get the hotspot working on a RB112 and continues giving Invalid on the Hotspot server page. I have tried setting it up manually in Winbox, manually from the CLI, with the setup command in winbox and CLI, and reset to factory and run the setup script from winbox. All the same problem. I run the setup on a different (new) RB112 and the same thing. When I run it on one of my Intel boxes running the same version of MT it works like it's supposed to. I have been at this for over 8 hours and enough is enough. Using RouterOS for routerboard v2.9.18 and 2.9.19. Any ideas or is this a problem in the OS for the routerboard.
Thanks,
John Dunham
GXC Corp.
ghmorris
Tue Apr 11, 2006 1:29 am
We have the same problem. Works fine on a 532, won't work at all on a 112
George
GotNet
Tue Apr 11, 2006 1:39 am
OT but since RB112 users are of short supply...
What free disk space do you have on your 112s? I'm showing 57 meg used with 7.7 meg of packages.
And sorry - I'm not using hotspot.
Mike
jldunham
Tue Apr 11, 2006 2:28 am
It has the 64Mb flash and about 50% used. If it does not work on the 112 then I wasted my time. Have to have hotspot, that was the primary reason for getting it. Do not need a large amount of users or throughput.
marlow
Hotspot / RB112 / invalid
Wed Apr 12, 2006 11:42 pm
I see the same problems here, with Hotspot on RB112's.
If you use the setup wizard in WinBox, it'll be invalid, if you then delete the hotspot and recreate it, it's ok until you reboot or change the underlying hotspot server profile. This is an issue in 2.9.19 and 2.9.20. I'm down to that I will try to downgrade the package now, step by step, see if it ever worked.
/Marlow
Communication is the beginning of understanding
-- AT&T
normis
Thu Apr 13, 2006 10:20 am
hotspot will be fixed for RB112 in next RouterOS (2.9.21)
marlow
Thu Apr 13, 2006 12:38 pm
Good stuff. Looking forward to that.
/Marlow
-- AT&T
Users browsing this forum: No registered users and 23 guests
