wildbill442
RB951 / RB911 Auto negotiate problems
Mon Nov 25, 2013 9:25 pm
I have the following setup:
RB911 (5Ghz) <===> RB951Ui router
RB911 is plugged into POE port.
Won't negotiate higher than 10mbps Full Duplex with lots of packet loss.. 951 shows red light lit even when ethernet cable is unplugged from ether5.
both devices running RoSv6.6 and firmware 3.10
William Burnett
Network Engineer
wildbill442
Re: RB951 / RB911 Auto negotiate problems
Mon Nov 25, 2013 9:36 pm
Just had another customer call in with connection problems...
Similar issue:
RB911G-5HPnD -- Ether1 is only showing a 10Mbps half Duplex connection.
William Burnett
Network Engineer
wildbill442
Tue Nov 26, 2013 12:03 am
I've resolved both problems...
One appears to have been a Netgear router. Tried a new RB911, new POE's, still only got 10Mbps Half Duplex. Plugged into a new RB951 router, and got 100mbps FDX.
The other instance appears to have been a bad RB911.... Tried new router, new poe, everything was only showing 10Mbps FDX. Put in a new RB911 and got 100Mbps FDX.
Still don't know what caused the MDIX to fail, but a new RB911 fixed the problem.
William Burnett
Network Engineer
ddd
Tue Nov 26, 2013 3:48 am
Make sure your using a GBit POE
http://routerboard.com/RBGPOE
wildbill442
Tue Nov 26, 2013 7:48 pm
Why can't I use the built in POE port on the RB951?
Also I have another location where I'm doing fiber to the antenna due to cable distances. I have a remote reboot-able POE controller (http://tinyurl.com/d4523hv) and will be using R9xx Outdoor series.
The device is only rated for 100Mbps. Without it, the only way to manually reboot the devices would be to power down the entire tower, which, is unacceptable to me.
Your solution may solve a simple client side problem, but raises some major concerns for me if we MUST use these POE's for auto negotiate to work properly with RB9xx boards...
William Burnett
Network Engineer
wildbill442
Tue Nov 26, 2013 8:04 pm
I've opened a support ticket. Hopefully its just a bad board.
William Burnett
Network Engineer
iberfi
Tue Dec 17, 2013 3:10 pm
Very Interested as having a similiar issue where also the Ethernet Ports show as running, but are not passing any data.
They need a hard power boot to restore operations.
Any Ideas - getting this on alot of boards installed.
Users browsing this forum: adrianh, Cliff007 and 24 guests
