jeremyh
RB751n flaky after upgrade 5.24 -> 6.5
Thu Nov 28, 2013 9:25 am
Hi
I have a RB751n sitting around which was running 5.25 (or similar). I updated it to 6.5 by uploading the mipsbe .npk over the web interface.
It took a long time (5+ minutes to update). After 10 minutes, I got impatient and pulled the plug on it. When it rebooted, it took a few minutes to start working again.
Now it is running (NAT, DHCP, Bridge etc) but.. Winbox is VERY slow to log in, and if I can log in, doesn't show data (interface list is blank). SSH times out. HTTP web page times out.
The router seems to be functioning normally otherwise, and Winbox reports it is running 6.5. But it's obviously not right - what did I do wrong.. and how can I fix it?! :(
Jeremy
InoX
Re: RB751n flaky after upgrade 5.24 -> 6.5
Thu Nov 28, 2013 8:00 pm
What is the cpu usage?
scampbell
Trainer
Trainer
Thu Nov 28, 2013 8:15 pm
A couple of suggestions....
1. Check the RB751 is running the new FW as well. In Winbox go to SYSTEM.ROUTERBOARD and see if you are running the latest. If not click upgrade and reboot.
2. Try re-installing using netinstall and check the otion to "keep configuration"
Hope this helps.
jeremyh
Fri Nov 29, 2013 8:34 am
Thanks for the replies. The firmware seems to be the latest, but the CPU, memory and disk graphs seem odd..?
Thanks,
Jeremy
InoX
Fri Nov 29, 2013 7:07 pm
Tools->Profile
Users browsing this forum: No registered users and 15 guests
