jml
S-31DLC20D GBIC compatible with Cisco3750?
Mon Dec 09, 2013 2:35 pm
Hi guys,
I was wondering if anyone has tried a S-31DLC20D GBIC in a Cisco 3750 Catalyst and had success.
We are going to be transitioning to Mikrotik HW on this particular switch, but I need a fiber circuit up ASAP and I really don't want to spend hundreds on a GBIC that's Cisco only.
sergejs
Re: S-31DLC20D GBIC compatible with Cisco3750?
Mon Dec 09, 2013 4:08 pm
Please make sure your switch device does not have proprietary lock for SFP modules, you need to study Cisco documentation.
timberwolf
Wed Dec 11, 2013 2:43 pm
Cisco products only supports their own SFPs, other SFPs don't work.
But you may have a look here, maybe it helps: http://www.flexoptix.net
ChrisP
Fri Dec 13, 2013 11:03 am
I don't have a S-31DLC20D to test, but Cisco 3560/3750 switches can support 3rd party SFPs if you enter the following commands:
service unsupported-transceiver
no errdisable detect cause gbic-invalid
The first allows non-Cisco SFPs and the 2nd stops SFPs being put into the err-disable state.
Users browsing this forum: No registered users and 16 guests
