medube
Power Break during Upgrade
Fri Apr 21, 2006 12:00 pm
I was recently upgrading my RB532 and had a power break in the middle. Since it came back up, I cannot seem to have any communication with the borad. Though it powers up as normal but I cant seem to have any contact with it.
Is there anything I can do, please help...
VicNet
Fri Apr 21, 2006 12:31 pm
Very bad, :cry:
Your board is broken.
Please contact with your board suppiler mayeby they can help you.
medube
Fri Apr 21, 2006 12:33 pm
Ok. If I slot in a CF card will it override the onboard memory and load from CF?
normis
how about output from serial console?
medube
Fri Apr 21, 2006 12:34 pm
Hi I tried to see it thru serial, I get Loading fro Nand OK and then it goes System Halted.
normis
Fri Apr 21, 2006 12:40 pm
try to reinstall RouterOS with netinstall:
http://www.mikrotik.com/docs/ros/2.9/guide/netinstall
medube
Fri Apr 21, 2006 1:51 pm
Thank you Normis, so far I have been able to install using netinstall. After the first reboot it goes thru all the normal bootup process, but then just stops on Starting Services...
Is there anything else I must do?
Thanks again
cmit
Fri Apr 21, 2006 1:52 pm
Try changing your baudrate. Sounds like the console could be configured to use another baud rate...
Best regards,
Christian Meis
medube
Fri Apr 21, 2006 2:01 pm
Thank you guys, it worked out well. I really appreciate the assisstance and suggestions.
Thanks again
Users browsing this forum: aboiles and 31 guests
