welan
CCR1036-12G-4S and Winbox MAC Access
Tue Jan 07, 2014 8:25 pm
Hi to the forum,
I have problems accessing via mac address to the router in subject.
The router is upgraded to the latest version of ROS, it never went into production and has had this problem since its purchase.
The installed version of the initial ROS was 5.8. Now is the 6.7
Any suggestions?
Many thanks.
PS.. i reset it to defaults but nothing
welan
Re: CCR1036-12G-4S and Winbox MAC Access
Tue Jan 14, 2014 11:05 am
No support? :( Normis?
normis
Tue Jan 14, 2014 11:40 am
Initial version could not have been v5.8, since CCR only runs on v6.
Did you try connecting from a different ethernet port? Is the LCD showing anything ?
welan
Tue Jan 14, 2014 12:33 pm
Many thanks for your answer.
I tested all ports, same problem.
I do not want to contradict you but version 5.8 was originally installed with a sticker that recommends the upgrade to 6.0.
I bought the CCR just came out on the market, is serial is 42A102E22302 / 302.
I have experience with Mikrotik device, with more than 2000 devices including RB, Groove, etc.. and this is the first time I encountered this problem.
Any solution?
WirelessDSL
Wed Jan 15, 2014 4:21 pm
I have the same problem only with CCR´s.
The other Routerboards connecting fine via MAC-Address.
What kind of OS you are using?
I´m using Windows 7 and I can´t get the CCR MAC-Connection working. It only works via IP-Address.
On other PC´s (XP, Vista, also with Win7) there´s no problem.
Usually there can be a problem with MAC-Winbox if you have something like Virtualbox installed. Just disable the Virtual-Network-Adapter and it starts working.
But this trick doesn´t work for me with CCR.
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCINE
conchalnet
Wed Jan 29, 2014 3:46 pm
Hello, did you solved the problem?
We have the same issue here! If we are using winbox on windows 7 we can't access the CCR by MAC Address.
Best regards
TaisPH
Wed Feb 12, 2014 12:59 pm
I have the same issue here.
Brand new CCR-1036. Winbox sees it but hangs forever when connecting to HW/MAC address. mactelnet cmd connects to same HW address without problems.
This is on Ubuntu 13.10 btw.
sterb
Fri Feb 21, 2014 10:44 am
Have the same problem using Windows 8.1 connecting to 1016 and 1036 (v6.10) - everything works as expected just MAC winbox has port 20561 timed out error.
plisken
Fri Feb 21, 2014 4:15 pm
Try disable the firewall in windows.
I have that to and with disable firewall con i connect
TaisPH
Fri Feb 21, 2014 4:23 pm
As I noted, the exact same issue exists in Winbox under Wine in Linux. No firewall.
sterb
Fri Feb 21, 2014 4:45 pm
Cannot be that as MAC access to other HW platforms is fine with the same client.
hedon
Fri Mar 07, 2014 6:09 pm
Today I unpacked third CCR-1016-12G.
First one died within 10 minutes of working.. returned..
On second one, 5 ports died... returned..
Now I powered on third one. I connected normally from Winbox to MAC address, pressed remove configuration and now I'm
unable to connect any more to MAC. Next I did reset configuration and I can now connect to default IP, but MAC is not working on any port.
MAC Server is defined ok. I can connect to other devices within network, but not CCR.
CCR is a disappointment so far.
sterb
Sat Mar 08, 2014 12:33 pm
Give it an IP using the touchscreen then connect via IP.
hedon
Sat Mar 08, 2014 12:38 pm
Thank you so much for this completely useless tip.
This thread is about MAC access problem.
sterb
Sat Mar 08, 2014 12:45 pm
I misread your post as I had the same problem when I got rid of the default config, no longer an IP no MAC access and my fix was as per my response.
Good luck getting help in the future with your attitude...
hedon
Sat Mar 08, 2014 1:15 pm
I apologize for my attitude.
This device made me so much problems, that only help which would really satisfy me, would be to use a hammer on it.
Quality of this device is absolute garbage.
docmarius
Sat Mar 08, 2014 3:17 pm
Did you enable the MAC Server under /tools?
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
sterb
Sat Mar 08, 2014 6:58 pm
Yes, this is on by default.
dw5304
Wed Apr 09, 2014 4:44 pm
Same issue here... unable to mac-telnet to ccr device
sirmav
Tue May 20, 2014 10:08 am
Same issue here. Unable to mac-telnet to ccr device. But mac telnet from other routerboard to ccr works.
ScottReed
Thu Oct 23, 2014 7:28 pm
This is still an issue.
Just got new CCR1036-12G-4S and cannot connect via MAC Winbox.
Same issue with my CCR1016
Have tried from multiple laptops.
nz_monkey
Fri Oct 24, 2014 2:03 am
We have experienced this on:
CCR1009-8G-1S-1S+
CCR1016-12G
CCR1036-12G-4S
CCR1036-8G-2S+
So it seems to be a problem on the Tilera based systems.
PPC and BIPSBE still work properly.
I have just been doing a base config via serial, then connecting via IP with WinBox.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
SystemErrorMessage
Tue Nov 04, 2014 4:21 pm
update to latest routerOS. The first thing anyone should do when getting a new hardware is obviously to update it. winbox via MAC works fine for me.
Try using winbox to scan and select the MAC instead of IP. It does work but you may need to give it time to scan.
momikh
Mon Dec 29, 2014 6:34 am
Try to use old version of WINBOX please
andreacoppini
Trainer
Trainer
Sat Aug 29, 2015 4:02 pm
I had the same issue in 6.28
It seems fixed in 6.31
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
alejandroarenas2104
Tue Jan 05, 2021 6:21 pm
Hello, I have a problem accessing my ccr1036 via Winbox by public ip ... I have already updated it to the latest stable version and also to the one in test and the error persists .... please help
alejandroarenas2104
Tue Jan 05, 2021 6:23 pm
Users browsing this forum: No registered users and 32 guests
