gabrielfast
Error Install Mikrotik Server HP DL380e GEN8
Wed Feb 05, 2014 3:09 pm
Someone can tell me how to solve this error the annex.
AnRkey
Re: Error Install Mikrotik Server HP DL380e GEN8
Wed Feb 05, 2014 3:21 pm
RouterOS does not support RAID cards. Your server most likely has one. Try to enable IDE mode for the volume that you're trying to boot from in the RAID card settings. Otherwise, you'll need a SATA or IDE interface card and disk installed to proceed. You can also try installing to flash if that helps, but then you can't run services that are heavy on disk usage like the web proxy cache.
MTCNA
gabrielfast
Wed Feb 05, 2014 9:00 pm
I understand there can be clearer
gabrielfast
Thu Feb 06, 2014 1:50 am
not understand
AnRkey
Thu Feb 06, 2014 11:55 am
Send me the hardware specs of your server. Then maybe I can see if RoS will work on it or not. Try and give me the exact list of hardware in the server.
The card that the hard disk drives plug in to is important. If you can let me know what brand of disk and the brand of the card you have then it will be easier to help.
I'll try and be more clear in my follow up post once you have posted the specs here.
MTCNA
Users browsing this forum: dilu, usern and 21 guests
