honzam
rb951-2n future suggestion ?
Wed Feb 05, 2014 9:14 pm
Have you plan make rb951-2n with internal mmcx connector and USB?
Both works. Better than soldering is to buy a ready-made Mikrotik :)
http://www.zero13wireless.net/foro/show ... d-RB951-2n
LAN, FTTx, Wireless. ISP operator
rickfrey
Trainer
Trainer
Re: rb951-2n future suggestion ?
Wed Feb 05, 2014 10:49 pm
:-D
Launch your company forward with professional training!
http://rickfreyconsulting.com/product-c ... raining-2/
honzam
Fri Feb 07, 2014 11:32 am
When the board is ready for USB and MMCX and can be easily fitted components...
Please make a version rb951U-2n
jnygard
Wed Feb 19, 2014 9:06 pm
Tried the USB mod on my 951-2n... Does not work. No power supplied to the connector at all. Bummer!
jnygard
Wed Feb 26, 2014 8:10 am
OK, by feeding the USB port externally with 5V then the port comes alive but on the board there doesn't seem to be a point where to pull 5V from. Would need to build one from the main power line. Seems like the system is more or less running on a 3.3v voltage...
Users browsing this forum: No registered users and 14 guests
