JanezFord
crs125-24g-1s-2hnd-in wall mount
Mon Feb 10, 2014 9:25 pm
I cant seem to find any info or bottom side pictures of crs125-24g-1s-2hnd-in .... so I ask here ... can it be wall mounted in a same way as rb2011-uas-2hndin or rb951g-2hnd - just hung on 2 screws ?
TNX.
JF.
efaden
Re: crs125-24g-1s-2hnd-in wall mount
Mon Feb 10, 2014 9:30 pm
TNX.
JF.
Just looked at the bottom of mine... no holes.
JanezFord
Mon Feb 10, 2014 9:56 pm
Damn ... will have to figure out something else to have it wall mounted for a customer .... thanks for your info.
JF.
efaden
Mon Feb 10, 2014 10:03 pm
JF.
NP... you could always get the rackmount version and a vertical mounted rack... but then you loose wireless.
normis
Tue Feb 11, 2014 1:31 pm
Thank you for the suggestion, we will consider this for a future revision.
bladepopper
Mon May 26, 2014 6:32 pm
Hi, it's been a few months now, are the CRS125-24G-1S-2HnD-IN wall mountable now?
Users browsing this forum: No registered users and 22 guests
