alger
System rebooted because of kernel failure
Wed Mar 12, 2014 2:43 pm
Sveiki !
several times a day the router reboots:
jan/01/2002 05:00:01 system,error,critical System rebooted because of kernel failure
jan/01/2002 05:00:01 system,error,critical router was rebooted without proper shutdown, probab
ly kernel failure
/system resource print
             uptime: 4m45s
            version: 6.10
         build-time: Feb/12/2014 13:46:18
        free-memory: 3676.0MiB
       total-memory: 3969.0MiB
                cpu: tilegx
          cpu-count: 36
      cpu-frequency: 1200MHz
           cpu-load: 0%
     free-hdd-space: 903.6MiB
    total-hdd-space: 1024.0MiB
  architecture-name: tile
         board-name: CCR1036-12G-4S
           platform: MikroTik
what to do ?
rextended
Re: System rebooted because of kernel failure
Wed Mar 12, 2014 3:02 pm
Downgrade to 6.7 and wait 6.11
I'm Italian, not English. Sorry for my imperfect grammar.
alger
Wed Mar 12, 2014 3:20 pm
tell me please where i can download old version?
rextended
Wed Mar 12, 2014 3:45 pm
PeterNelson
Wed Mar 12, 2014 4:39 pm
In case switching to older version doesn't do the trick for you then you should check the RAM of your system. It can be because of a bad RAM too.
normis
Wed Mar 12, 2014 4:40 pm
simply send supout.rif file to support@mikrotik.com
kernel failure should be documented there
downgrading will not get the problem fixed for next release, if you don't report to support
alger
Thu Mar 13, 2014 3:09 pm
this file contains information such as ip address, vpn user logins. I can't share this information
normis
Thu Mar 13, 2014 3:19 pm
we can't fix bugs in any other way. is this really more important than your router crashing?
alger
Fri Mar 14, 2014 7:17 am
after downgrade uptime: 15h49m25s
             uptime: 15h49m25s
            version: 6.7
         build-time: Nov/29/2013 13:37:20
        free-memory: 3705.0MiB
                cpu: tilegx
          cpu-count: 36
           cpu-load: 0%
     free-hdd-space: 904.7MiB
           platform: MikroTik
alger
Fri Mar 14, 2014 7:24 am
In versions of ROS 3 update set without worrying about problems. Now, before installing updates will think 10 times to do it or not. The situation with the stability ROS worse and worse. Really wanted to before the update is more thoroughly teste
nachollv
Sat May 24, 2014 1:25 pm
I`ve the same problem with Routeros 6.13 and routerboard 411 UAHR
What can i do?
uldis
Mon May 26, 2014 1:24 pm
What can i do?
make a support output file after the kernel panic and send it to support@mikrotik.com
nachollv
Mon Jun 16, 2014 11:12 pm
Ive sent You the support file but i did not receive any answers
CoriXL
Thu Sep 18, 2014 8:39 pm
Dear Collegues,
we had same problem on CRS and 1100AHx2 with one ospf and some eoip runnings on it, the OS where 6.19 for CRS and 6.15 for 1100AHx2.
Frustrated from continous reboots of routers we used 2 RB2011 as spare one old with OS 6.7 start to work and now is 27 hours without reboot
secon where with OS 6.19 and still rebooting all day. At he and we dowgraded also the second to 6.7 and now seem stable.
whe opened tikets for that Ticket#2014091766000231 and Ticket#2014091666000626
I hope this description helps also MikroTik developpers
3ttelecom
Thu Sep 25, 2014 3:35 am
Same problem here!!!
Kernel failure!!!!
LuizMeier
Mon Sep 29, 2014 6:24 pm
I'm having this same issue on a 1100AHx2
uptime: 1h3m21s
version: 6.19
build-time: Aug/26/2014 14:05:51
free-memory: 1485.8MiB
total-memory: 1518.7MiB
cpu: e500v2
cpu-count: 2
cpu-frequency: 1066MHz
cpu-load: 0%
free-hdd-space: 88.2MiB
total-hdd-space: 128.0MiB
architecture-name: powerpc
board-name: RB1100AHx2
platform: MikroTik
plisken
Mon Sep 29, 2014 6:37 pm
Running you scripts ore something?
LuizMeier
Mon Sep 29, 2014 6:53 pm
I just did the upgrade from 6.11 to 6.19 and after that it rebooted twice by kernel failure. After the third reboot, it stopped. Maybe because I changed some VRRP scripts?
This RB is being used on a test enviroment (thanks god!) for VRRP. I will use It and other RB1200(that has been upgraded as well and did not had problems) to have HA on my gateway to the internet.
There is one strange thing about this router, that is it's not running On Master and On Backup scripts when VRRP interface's state changes. I have the same scripts on both routers and no problem on 1200. 1100 simply ignores the scripts.
plisken
Mon Sep 29, 2014 7:01 pm
Try with netinstall procedure.
See on my website for the correct procedure.
http://www.wirelessinfo.be/index.php/mi ... etinstalle
jml
Wed Oct 01, 2014 2:51 pm
Just had this happen to me with 6.13 on a CCR1036...after about 90 days of uptime.
However crashes started happening every 5 minutes.
Upgraded to 6.19, been up 8 hours so far with no issues. We will see what happens when the traffic picks up today, but frankly I'm nervous.
I will be sending the supout to mirkotik.
One question, what x86 hardware do people use for RouterOS? Some have suggested it's much more stable than CCR.
plisken
Wed Oct 01, 2014 5:26 pm
aeg
Mon May 25, 2015 6:48 am
Same problem here several time per day
uptime: 5m20s
version: 6.28
build-time: Apr/15/2015 15:18:31
free-memory: 37.1MiB
total-memory: 64.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 3%
free-hdd-space: 46.8MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 288
write-sect-total: 288
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB2011L
platform: MikroTik
may/17 09:27:12 system,error System rebooted because of kernel failure
may/17 09:27:12 system,error Out of memory condition was detected
may/17 09:27:12 system,error router was rebooted without proper shutdown
may/17 09:27:11 system,error,critical router was rebooted without proper shutdown
by watchdog timer
Funny the time is off in the logs... i guess it is because the router is not yet up to the point he knows that he is in Pacific/Auckland +12
Mikrotik76
Tue Jan 03, 2017 2:07 am
I have the same issue with 3 CRS210-8G-2S+IN. I send you supout.rif but have no answers yet. It appears several times per hour now. Please find a solution quickly.
Wyz4k
Tue Jul 04, 2017 7:29 am
Getting this issue on one router running ROS6.38.5
strods
Tue Jul 04, 2017 4:14 pm
Kernel failure message says - there was a problem with router. What kind of problem - you can not say just by seeing log message.
If you experience kernel failure reboot, then upgrade router to latest RouterOS version. If problem persist also after upgrade, then after kernel failure generate supout file on your router and send this file to support@mikrotik.com. No one else will be able to tell what was the problem.
Wyz4k
Wed Jul 05, 2017 3:52 am
I have submitted a supout.
djape
Wed Aug 16, 2017 3:58 pm
Guys, change power adapter before anything else.
It happened to me many times and each time was faulty power adapter.
I drink like a pirate and smoke like a hippie...
Wyz4k
Wed Aug 16, 2017 4:18 pm
I received this response from Mikrotik support one or two days ago: This issue is already fixed in the latest Release Candidate version of RouterOS.
strods
Wed Aug 16, 2017 4:38 pm
Always in such case send supout file from your router to support@mikrotik.com. We are the only ones who can try to see what went wrong with your router. It is not possible to simply guess cause of the reboot in forum. Make sure that file is generated after router has rebooted with latest current version. It would be great if in such case you could also test next version rc version.
This will definitely will be the fastest solution for your problems. Also if there indeed is software related issue, then we need to know about it in order to fix it.
Wyz4k
Thu Aug 17, 2017 5:07 am
Further response:
from 6.41rc13 change-log:
*) lte - improved reliability of USB LTE modems;
if possible please test this in isolated environment, because we are getting mixed reviews from customers about this fix usefulness.
Even though it says just USB LTE modems this also affects miniPCI-e:
Yes, same USB drivers are loaded for miniPCI-e and USB modems.
Please give us feedback if possible, so we can see if this fix fixes this issue.
Users browsing this forum: No registered users and 14 guests
