MUM Europe 2020
alexwaller
POE out not working on OmniTIK UPA 5HnD
Tue Mar 18, 2014 1:42 am
We use:
OmniTIK UPA-5HnD as AP and
SXTG-5HPnD-SAr2 for connection to other sites.
All ros 6.10 and upgraded firmware. We use original MT POE injectors and power supply.
OmniTIK is powered by POE-in over CAT7 wire. SXTG is powered from then OmniTIK with POE-out.
At least that was planned like that! But the SXTG doesn't boot. It had not enough power to do so. The lights slightly flashed and the thing ticked.
So we got the OmniTIK and the SXTG in Office for testing...
Everything is OK when we use a network cable shorter than 5 meters to provide the OmniTIK with power.
As it is a 5 meter cable there is no power for the SXTG. There is always power for the OmniTIK itself.
It makes no difference which port is used and if POE-out is "forced on" or "auto".
We tested two other OmniTIK with the same Result. Also with other ros versions.
And we used different POE-out gadgets like RB2011UiAS-2HnD-IN or RB951G-2HnD. That didn't make a difference.
How to fix this problem?
patrickmkt
Re: POE out not working on OmniTIK UPA 5HnD
Tue Mar 18, 2014 3:55 am
With longer cable you probably want to increase the voltage of the power supply. Also check the amp rating of your psu. Do you have enough margin of power to supply both unit together including the increased loss in the cable?
alexwaller
Tue Mar 18, 2014 11:25 am
It works when we are using two 3m cables.
It doesnt work when we use a 5m and 3m cable.
That length should not make any diffrence, right?
We use the PSU of the OmniTIK wich is 24V 2,5A.
pilotnz
Wed Mar 19, 2014 4:41 am
Hey alexwaller,
open console on OmniTIK and type: /interface ethernet poe settings set ether1-poe-in-long-cable=yes
Good luck!
Regards,
Petr
ddd
Wed Mar 19, 2014 7:21 am
Hey alexwaller,
Good luck!
Regards,
Petr
When all else fails its always solved by a secret setting.
jarda
Wed Mar 19, 2014 7:45 am
Hey alexwaller,
Good luck!
Regards,
Petr
Or by soldering - it's my favorite.
Sent from Android by Tapatalk.
plisken
Tue Apr 01, 2014 9:26 pm
Is this problem solved?
I soldered the POE (looks to the picture) for me is that the best solution to have a stable POE
jarda
Wed Apr 02, 2014 8:34 am
I am soldering right behind the ports - shorter way is better way for electricity.
plisken
Wed Apr 02, 2014 9:56 am
Can you made a picture and publisch here please?
janisk
Wed Apr 02, 2014 10:49 am
Hey alexwaller,
Good luck!
Regards,
Petr
yes, these secret settings (that are listed in manual):
http://wiki.mikrotik.com/wiki/Manual:Po ... l_settings
jarda
Wed Apr 02, 2014 8:27 pm
Here it is:
alexwaller
Wed Apr 02, 2014 10:24 pm
Hey alexwaller,
That worked perfect!
As maybee anyone will use a cable longer than 5m with that OmniTIK, why is it set to "no"?
Anyhow, now the project is finished and all three MT are working as supposed.
Thanks to all!
geardi
Wed Apr 08, 2015 2:03 am
Can you help me, I have a problem with Omnitik U-5Hnd , when i turn on, All Lans dont work except PoE that works , PoE Light works but Lan lights dont work any , I've reset but still dont shows no IP in WinBox .
Petzl
Sun Apr 12, 2015 12:52 pm
Does the ethernet link come up on the laptop / switch side ?
For configuring use Ether 2-5
elcad
Tue May 31, 2016 6:43 pm
I supposed this answer is joke. But it really works ! Then I have a question!
: Why manufacturer sets such mad willful option and donť set this option as default to sold devices ??? What sense has this secret option?
Hey alexwaller,
Good luck!
Regards,
Petr
Users browsing this forum: BonDyaRa, uldise and 10 guests
