alialiraqi
normal temp of RB912??
Wed Apr 09, 2014 11:14 pm
I have an rb912uag-hpnd-outdoor, connected to this antenna http://www.wireless-instruments.com/en/ ... -17hv.html
the problem is that its problem is getting very hot on the burst client-use time ( on evenning ) it reahcs about 55C for just 4 clients.
you can see the attached image.
where I have heared that this board can withstand about 60 clients.
is 55c a normal temperature for rb912?
Can I reduce the temperature to save the board from being damaged?
what is its maximum accepted temperature?
regards
alialiraqi
Re: normal temp of RB912??
Thu Apr 10, 2014 1:51 am
the board is not too hot when there is no download over it
lunchboxrts
Thu Apr 10, 2014 10:18 am
Our 912's haven't broke 39c under heavy load.
jnygard
Fri Apr 11, 2014 11:55 pm
What is the ambient temperature that the box is in?
plisken
Mon Apr 14, 2014 7:18 pm
How much is the ambient temperature?
Maby a ventilator is the solution of this
janisk
Tue Apr 15, 2014 1:21 pm
ambient temperature is important but most important is what data-rates are used by wireless interface. Lower data rates usually come with higher transmit power. To overcome this, get better link quality.
Users browsing this forum: No registered users and 36 guests
