noyo
Lite5 and bad blocks [resolved]
Sun Apr 13, 2014 9:52 pm
I counted about 15 pieces lite5 which are from 0.1 to 0.5% bad blocks, which one of them disappeared configuration of VPNs.
Lite5 than have the time.
Could defect lite?
normis
Re: Lite5 and bad blocks - defect lite ?
Mon Apr 14, 2014 12:42 pm
This is a very small number of bad blocks, and will not affect the device performance in any way. You should not be worried, this is acceptable. RouterOS doesn't use the blocks marked as bad.
please make sure you are running the latest RouterOS version 6.11, and send a supout.rif file to support. It is probably related to something else.
noyo
Mon Apr 14, 2014 1:23 pm
it is very funny hahaha new antenna and already damaged
6.11 is crappy, bug, bug, bug.
Every restart, setting vpn (secrets) disappear
normis
Re: Lite5 and bad blocks [resolved]
Mon Apr 14, 2014 1:35 pm
According to chip NAND manufacturer, this is acceptable number from NAND chip factory.
This is not related to your blocks. The bug is fixed in v6.12, you can email support and ask for test version, if it is very urgent.
noyo
Mon Apr 14, 2014 1:47 pm
I have a 5.26 everywhere and anywhere will only work where there are bad bloks disappears.
normis
Mon Apr 14, 2014 2:07 pm
Blocks don't disappear. The only explanation could be, that v5.26 doesn't count them correctly ...
noyo
Mon Apr 14, 2014 2:13 pm
When will the very stable version 6.x ?
normis
Mon Apr 14, 2014 2:14 pm
RouterOS v6.12 will have the fix for your VPN problem
Users browsing this forum: SiB and 21 guests
