Ibersystems
CRS226-24G-2S+ backwards compatible with S-85DLC05D?
Tue Apr 29, 2014 10:33 am
Acording to another post in the forum, one CCR with SFP+ slot can use SFP transceiver if you fix the rate to 1GB and disable autonegotiation.
It's not possible to make this with this CRS?
The SFP modules are recognized but the link is not working. I'm using the same modules and fiber wire that connects and work in two RB2011.
What the problem? I tryed LOW and HIGH in rate selection and 1GB or 100M full duplex without autonegotiation.
Martín Ruiz
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in:
MTCNA - MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE - MTCSE
Ibersystems
Re: CRS226-24G-2S+ backwards compatible with S-85DLC05D?
Tue Apr 29, 2014 10:41 am
SFP Two 10G Ethernet SFP+ cages (Mini-GBIC; SFP module not included), DDMI support.
First port supports 1.25G/10G modules, second port only 10G modules.
Why the second is not compatible and why I'm not able to put the first one working?
Martín Ruiz
Certified in:
normis
Tue Apr 29, 2014 10:52 am
Because of a hardware limitation, SFP+1 supports 1.25G and 10G modes, SFP+2 supports only 10G mode
This is also mentioned in the manual: http://i.mt.lv/routerboard/files/crs-se ... 104753.pdf
Ibersystems
Tue Apr 29, 2014 11:09 am
Yes, It was my fault to not read carefully the brochure, but what's the problem with my config?
I'm not able to put the SFP+ number 1 working at 1Gbps with your SFP module.
Martín Ruiz
Certified in:
Ibersystems
Tue Apr 29, 2014 11:14 am
What I'm looking at.. is a Board with 2 SFP at 1 Gbps... there is only one with 36 core.. too expensive. I need a board to receive via fiber and send to other node via fiber also.
I hav a CCRXXXX36-4S in the main site and I have to move a fiber to node 1 and from node 1 to node 2.
Request: A cheaper board with more normal SFP, not SFP+.
Martín Ruiz
Certified in:
honzam
Tue Apr 29, 2014 11:25 am
For example: rb953gs-5hnt
http://www.2imgs.com/32c494be6d
LAN, FTTx, Wireless. ISP operator
Ibersystems
Tue Apr 29, 2014 11:29 am
Do you have it in stock? ; ))))
Martín Ruiz
Certified in:
honzam
Tue Apr 29, 2014 4:33 pm
Kreacher
Sat May 31, 2014 1:52 pm
Any news on this RB?
Kindly regards
Kreacher ♬
Karma points must not be paid by you
Users browsing this forum: No registered users and 11 guests
