MUM Europe 2020
HellMind
Installing Routeros Without Serial Connection
Sun Jun 15, 2014 1:48 am
I got a RB433 installed with Openwrt.
Is there any way to install routeros again, without local access, just with ethernet?
Anyone succeeded installing routeros from Openwrt?
HellMind
Re: Installing Routeros Without Serial Connection
Sun Jun 15, 2014 2:29 am
Maybe someone got a routeros 5 image in .bin ?
jarda
Sun Jun 15, 2014 9:19 am
Maybe netinstall could do the job.
HellMind
Sun Jun 15, 2014 10:38 am
Netinstall requires Serial port
The equipment is mounted on a tower.
HellMind
Sun Jun 15, 2014 10:40 am
Maybe there is a way to do this:
system routerboard settings set boot-device=try-ethernet-once-then-nand
In openwrt
HellMind
Wed Jun 18, 2014 2:07 am
Can anybody help me flashing my rb411u without the serial port?
normis
Wed Jun 18, 2014 3:58 pm
Netinstall does not require a serial port. Just hold the reset button before you apply power. Keep holding the button until the router shows up in Netinstall window. Then release button.
HellMind
Wed Jun 18, 2014 4:02 pm
Is there a way to do this without pressing that button?
The board is on a tower. I can't bring it down, just to flash it.
Maybe there is a way to enable the bootp with the ethernet port?
normis
Wed Jun 18, 2014 4:04 pm
You have no access to console, to button or to software. I would say, climbing is your only option.
HellMind
Wed Jun 18, 2014 4:09 pm
Isnt a way to simulate the pressing the reset button by crossing some contacts on the ethernet port?
normis
Wed Jun 18, 2014 4:15 pm
Sorry there is not
jarda
Thu Jun 19, 2014 9:35 pm
But it could be implemented, couldn't it? It would be useful.
Users browsing this forum: No registered users and 24 guests
