Alfabi
RB1000 PROBLEM - need advice
Fri Jul 25, 2014 3:18 pm
im just look on my rb 1000 and see frequency 1500mhz, so try put 1000 and receive massege "no supported change frequency" only 1500 .... im try older version mikrotik 6.20 6.10 5.20 5.10 5 and the same situation so firmware is 2.30 always ..... please give advice how to set 1000!!!!!!!!!!!
http://www.bios-computer.com - Fastest WISP in UA
rextended
Re: RB1000 PROBLEM - need advice
Fri Jul 25, 2014 3:48 pm
If you can, use one serial cable to reset bios (the only point where cpu speed are stored) after reset, chose inside the bios (on serial port) the wanted speed.
The 1000 must run at 1333MHz with default 512MB on board.
I'm Italian, not English. Sorry for my imperfect grammar.
Alfabi
Fri Jul 25, 2014 5:15 pm
THX for advice..... im read manual .... opening box rb1000 set DIN correctly and all works fine 1333mhz, rb1000 was in exploitation around 5 years.... maybe forget
Users browsing this forum: cigamit and 37 guests
