MUM Europe 2020
Petzl
New product CRS 109
Thu Aug 07, 2014 12:26 pm
http://www.cdr.pl/p3630,mikrotik-cloud- ... nd-in.html
CRS109 8G 1S 2HnD IN
CPU Qualcomm Atheros AR9344 600MHz
Memory 128MB
Ethernet 8x 10/100/1000 Mbit/s Gigabit Ethernet with Auto-MDI/X
SFP One 1G Ethernet SFP cage (Mini-GBIC; SFP module not included), DDMI support.
Storage 128MB Onboard NAND with multiple OS partition support
Serial port One RJ45 serial port
Extras Reset switch beeper
voltage and temperature monitoring
touchscreen LCD
Power options 8-57V, 24V 0.8A PSU included
PoE in: 10-57V on Ether1 (802.3af/at or passive PoE)
Case dimensions 285x145x45mm
Temperature -35C to +65C tested
nz_monkey
Re: New product CRS 109
Thu Aug 07, 2014 1:11 pm
Hooray return of Real USB! And a RJ45 console port.
Mikrotik you guys rock. This is an awesome little product.
I am glad you are adopting the CCR look across your product range, it looks professional.
The only thing that could make it better is 802.3af/at POE out to run phones and AP's from.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
joegoldman
Long time Member
Long time Member
Thu Aug 07, 2014 2:52 pm
Good replacement for the RB2011UiAS-2hnd-in??
Same amount of CPU + RAM if I am not mistaken?
docmarius
Thu Aug 07, 2014 4:00 pm
MikroTik RouterOS v6, Level 5 license, free product lifetime upgrades
Is this the new "official" approach? No more "upgradable to" statement?
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
CyberTod
Long time Member
Long time Member
Thu Aug 07, 2014 4:03 pm
This has been the case for a long time. The "upgradeable to" field is deprecated.
normis
Thu Aug 07, 2014 4:05 pm
yes
docmarius
Thu Aug 07, 2014 9:57 pm
Thank you.
I know this was the politics on upgrades a long time now, but I never seen it written down as a commitment.
mpreissner
Fri Aug 08, 2014 12:26 am
When's this coming to the US? This would be perfect for a SOHO...and I imagine the price point (in US dollars) is rather attractive for the capability it has.
Michael Preissner
CISSP, CCSP, CEH, PMP
R1CH
Forum Veteran
Forum Veteran
Fri Aug 08, 2014 12:48 am
Another product with a CPU too weak for modern broadband connections :(.
bds1904
Fri Aug 08, 2014 1:21 am
funny, because every device I own still has the "upgradable to" field, even the 2011 that is only upgradable to 6.x, and it's running 6.18. Somehow I don't buy that.
As far as the switch goes, I think it is a step in the right direction. It would be really good for a on-site office that is 300ft of cable away. 1 device for fiber in, 8 PC's and wifi. It would also be beneficial to see this style device with a stronger processor (like a Scorpion 720Mhz CPU) and dual band wifi (or at least a PCIe slot) for a true SOHO device.
Mikrotik is kind of lacking in the SOHO department right now. Many small businesses I deal with have a 100/100 ethernet connection. Cloud services and pushing the need for SMB's with high speed connections. Mikrotik doesn't really have a device that can handle routing 200mbit (with decent firewall rules and a queue tree) in the sub $250 range.
Petzl
Fri Aug 08, 2014 1:29 am
I'm more intrested in a entry model with 2 or more SFP modules... since you now can buy 200 meter fiber cables with connectors on it.
What about support for a USB IO module,
- intrusion dection (one or more inputs)
- Temperature monitoring
- one or more outputs
nz_monkey
Fri Aug 08, 2014 5:24 am
OK my eyes were mistaken, I notice this actually has Micro USB A not a Standard USB A.
What is the thinking behind this decision?
Having the little cable hanging out the front to connect a USB flash drive or 3G modem looks ugly, and the micro ports are more flimsy and prone to damage.
normis
Fri Aug 08, 2014 8:46 am
This is a switch. For switches, CPU doesn't matter, since everything is done in the switch chip. Switching is done at wire speed.
honzam
Fri Aug 08, 2014 9:21 am
CloudRouterSwitch 109-8G-­1S-­2HnD-­IN (8 Ethernet ports, one SFP port, built in 2GHz wireless AP)
CloudRouterSwitch 112-­8G-­4S-­IN (8 Ethernet ports, four SFP ports)
LAN, FTTx, Wireless. ISP operator
KoDAk
Thu Aug 14, 2014 9:56 pm
it be better add WiFi to CCR1009-8G-1S (
Certified MTCNA
richinuk
Fri Aug 15, 2014 1:51 pm
+1. Really need a gig POE out device.
agehall
Fri Aug 15, 2014 9:08 pm
From the images, it looks like this product will have a fan. Is that really so?
I'm going to replace my network equipment at home and was hoping to get a couple of these babies for the WiFi, but as one would be sitting in the bedroom, I guess I'd get into trouble with the Mrs if it had a fan in it...
webspider
Sun Aug 17, 2014 9:50 pm
same CPU; exept the number of GB Ports exact the Same as the RB2011UiAS-2HnD-IN ?
just named it a Switch ?
Why no realy new, state of the art, modells ?
Greets Peter
sorry for bad writing, i'am no native English speaker.
honzam
Sun Aug 17, 2014 10:58 pm
RB2011 have 2 switch groups. First - SFP+ETH1-5. Second ETH 6-10
CRS 109 - Have 1 switch group - SFP+ETH 1-8
You have full 1GB speed on all ports if switching
+ 802.3af support
normis
Mon Aug 18, 2014 9:05 am
The switch chip type is quite different. RB2011 doesn't support so many swich specific functions as the CRS series. While switching is just an extra feature on the RouterBOARD models, it is the main function on the CRS models, and has a lot of functionality there.
janisk
Mon Aug 18, 2014 2:50 pm
it has no fans
agehall
Wed Aug 20, 2014 12:17 am
Awesome - I'll get two ASAP then.. ;)
stormeporm
Fri Aug 22, 2014 1:13 pm
Which switch chip is it using?
Wil it get the exact same features as the crs-125? This would be nice because I would like to play with the 125 but I don't need 24 ports. The 109 would be a nice test platform.
normis
Fri Aug 22, 2014 1:16 pm
It has all the same features
PavelRadvan
Fri Sep 05, 2014 5:31 pm
Is this product good for CAPSMAN for managing around 15-20 APs ? All the network is megabit and gigabit cables.
Thanks for reply
normis
Fri Sep 05, 2014 10:46 pm
Thanks for reply
Any RouterOS device can be a CAPsMAN controller, including this model
smala
Mon Sep 15, 2014 3:10 pm
+ 802.3af support
Hi all,
I am going to buy one of these models (RB2011UiAS-2HnD-IN or CRS109-8G-1S-2HnD-IN) for my new house. I am developer and not so good in networks at the moment.
My network will include:
1) two PCs (wired connection)
2) some laptops, phones (wifi connection)
3) one server with many virtual servers (OpenVZ containers)
+ 802.3af support
Does it mean that RB2011 will not have full 1Gb speed on 1-5 group?
One more question. As I understand one of the differences between switch and router is that switch cannot connect you to the internet (ISP)? So does it mean that I will have to configure CRS 109 for example ETH1 to be a "router"? How about RB2011? Is it the same?..
Please recommend one of these models
Thanks for a help,
have a nice day :)
Arunas, Lithuania
becs
Mon Sep 15, 2014 4:08 pm
Both of them will have full 1Gb speed on ether1-ether5 if ports do switching, both will have lower performance if ports do routing, because it utilizes CPU resources.
RB2011 also uses CPU resources for traffic forwarding between switch-chip1 [sfp1+ether1-ether5] and switch-chip2 [ether6-ether10].
Correct, you will have to configure routing - ether1 port for WAN (ISP) network and other ports for your local network which then could be switched and provide wire-speed connections.
It applies to both RB2011 and CRS109 and they have such configuration by default.
smala
Mon Sep 15, 2014 4:46 pm
Thank you! It is now much clearer.
From other comments I understood that CRS109 has more features, is it true?
I'm trying to choose between these two models. CRS109 is more expensive, and I need to know if I get more benefit from it ( I wont use 802.3af ).
I have one physical server (with many virtual servers), I plan to buy one more physical server, and I will try to configure routes between these virtual servers (http://wiki.mikrotik.com/wiki/Multiple_Web_Servers).
I'll try to configure VPN (just to learn it).
I plan to configure Network printer (if it is possible with mikrotik)
I have TV, and I need to watch films from one of my virtual server (DLNA server)
And of course I need stable WiFi connection in my home (especially for my wife).
Please suggest one of these models for me :)
Arunas
zyzelis
Mon Sep 15, 2014 6:04 pm
Normis, when to expect switch with 4 SFP ports? What about it's pricing?
becs
Tue Sep 16, 2014 9:35 am
smala,
Both RB2011 and CRS109 would provide very similar performance in your required setup. The main difference is that CRS109 has more Gigabit ports and more advanced switch-chip features for VLANs, Port Isolation, Link Aggregation and QoS.
CRS switch-chip description: http://wiki.mikrotik.com/wiki/Manual:CRS_features
RB2011 switch-chip description: http://wiki.mikrotik.com/wiki/Manual:Sw ... p_Features
smala
Tue Sep 16, 2014 10:07 am
smala,
Thanks for your help!
jarda
Tue Sep 16, 2014 6:20 pm
And one addition. Mikrotik doesn't have print server function.
smala
Wed Sep 17, 2014 4:05 pm
Will both of these products will get "free lifetime upgrades":
RB2011UiAS-2HnD-IN
and
janisk
Wed Sep 17, 2014 4:19 pm
yes.
hiroru
Sun Sep 28, 2014 10:42 am
Hi guys,
Could be possible, with this product, to load balancing two different wireless wan connections?
mikrotik --- wireless gateway 1 --- internet 1
-- wireless gateway 2 --- internet 2
Thanks!
ropeba
Tue Sep 30, 2014 12:14 pm
When we can expect CRS with better CPU?
Quindor
Tue Sep 30, 2014 12:19 pm
You don't! :D
You should see a CRS as a switch but because Mikrotik uses the same CPU as in some of their routers it also has RouterOS and some routing capabilities. It's not meant for it though, it's a switch and you should 99.5% use it for that purpose.
The CRS109 happens to have a fairly decent CPU comparable with the RB2011 making it very versatile, but don't expect them to release versions with even faster CPU's. That is what the CCR line is for.
Couple a CRS with a CCR using a cheap 10Gbit DAC cable and you have the ultimate combo!
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
ropeba
Tue Sep 30, 2014 4:55 pm
Ok, when we can expect RouterBoard with 24 ports? :) Or RB2011 with powerful cpu? Mikrotik does not have optimal router for FTTB installation!
Quindor
Tue Sep 30, 2014 5:30 pm
True that a "ideal" FTTH device currently isn't in their portfolio (*yet). I believe the recently introduced RB850gx2 would do great in regards of performance and size. By estimated performance figures it should be able to handle Gigabit NAT and routing with a 'not too complex' configuration.
It misses an SFP(+) port though. It does have 5x Copper Gigabit which should be fine for a FTTH device. You can always add a switch and media converter to achieve your FTTH goal. Not ideal, I know, but best possible right now I believe.
Or, if you have a bit bigger budget could get an awesome CCR1009 with an SFP and SFP+ slot, 8x Gigabit Copper and more (WAY more) performance. Performance with NAT and routing power of 5Gbps+! Downside, it has a bit of a noisy fan which might not be appreciated.
Maybe an RB850gx2 with a CRS109 could be a nice combination too. You would have to develop a config for it, but then you would have your SFP slot in the CRS109, a powerful router and more then enough ports. Max routing speed and NAT about 1Gbit I expect.
foomy
Mon Oct 20, 2014 3:11 pm
Hi all
Long time reader, first time poster.
Sorry to reopen this thread, but I am also trying to decide between CRS109-8G-1S-2HnD-IN or RB2011UiAS-2HnD-IN
I just have a few questions and I hope appreciate it if anyone can give me some info on it.
1. I know the CRS109-8G-1S-2HnD-IN is a switch and the ports can used for routing as well. Are only certain routing commands available on this router or will you have all the commands with security as you would do it on the RB2011UiAS-2HnD-IN?
I read on another thread that only certain switch commands are available on the RB2011UiAS-2HnD-IN because it is a router with switch functionality, so I was just wondering if it would be vice versa when it comes to the CRS109-8G-1S-2HnD-IN?
2. Do any of these two routers allow you to set up a WAN port for VDSL?
3. Do any of these two routers allow failover to 3G/4G/LTE?
I apologize if the questions are silly but I have read lots of threads and documentation but none cover the "smaller" things.
Thank you
Regards
foomy
macgaiver
Fri Oct 24, 2014 8:54 am
Long answer short -
If you need a router with "simple" switch combo - use RB2011,
If you need a router and "smart" switch combo- use CRS
Details:
Both devices are almost identical, except for number of ports and switch chip functionalities - switch chips on both devices have whole set of switching features, just CRS have a bigger set.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
celicas
Tue Nov 04, 2014 3:25 pm
1st time poster here!
I'd like to learn more about "a lot of functionality" in CRS. I am afraid the only documentation I found on switch features (chip) of RouterOS is
where there are particular references to a couple of extra rules for Atheros8316 & Atheros8327 (like "new-vlan-id" which i am interested in).
Where can I find a command reference for CRS ?
Thank you all support (or not) guys for your prompt replies to all members.
celicas
Wed Nov 05, 2014 9:45 am
Ref my previous post, I found where the CRS commands reference are:
Sorry for the mistake!
GaryMansperger
CRS 109 USB port
Wed Jan 07, 2015 9:06 pm
Can I put a hard drive in the CRS109 USB port? If yes, how do I set it up?
Thanks,
Gary
normis
Re: CRS 109 USB port
Thu Jan 08, 2015 3:18 pm
Thanks,
Gary
yes, you can. in RouterOS v6.24 you can go into the System -> Disks menu to format the drive.
After that, you can use the drive in many menus, for SMB, for Logs, for Proxy etc.
LubMich
Tue Jan 13, 2015 2:12 pm
I have got a question.
Is it possible to use external antenna with CCR 109? I would like to install switch inside 10’ metal box so I need to connect external antenna to have some wifi range.
chechito
Sat Feb 07, 2015 4:24 am
then the new ccr1009 passive cooled its for you
vrej
A simple question aboute CSR109 and its support for openvpn!?
Tue Dec 22, 2015 8:32 am
Hello All,
I want to buy a csr109, I'm new to MikroTik but I hope that I'd make the right choice and become a Microtiker ;)
so the question is as follows`
I want to know if I config the CSR109 as a openvpn server just as like serving 10.8.x.x vpn ips and on udp proto, with tun virtual interface,etc... and force to limit the bandwidth of client-ip range up to 1mbit for each , can this product support up to 500 openvpn clients at the same time ?! (clients will connected and apply for vpn connection over the internet not wifi)
and if it can't support I like to know why and which product of MikroTic can do this fever for me, near this range of price ?
thanks in advanced
Users browsing this forum: No registered users and 11 guests
