MUM Europe 2020
rextended
August new products, "ac" and others...
Thu Aug 14, 2014 5:58 pm
Cloud Router Switch 109-8G-1S-2HnD-IN
is new "small size low cost" member of our CRS series. It comes with eight Gigabit Ethernet ports and high power 1000mW 2.4GHz wireless. Product supports 10-57V and is 802.3af/at compliant!
http://routerboard.com/CRS109-8G-1S-2HnD-IN
mAP
The mAP is a tiny size wireless 2.4GHz Access Point with full RouterOS capabilities. It is very portable, since it accepts power from a wide variety of sources - USB, Passive or Active PoE (802.3af and 802.3at) and power jack. It also works as a PoE injector - the second Ethernet port provides up to 500mA of power to another device, for example, you can connect a SXT CPE device to it.
http://routerboard.com/RBmAP2n
NetBox 5
802.11ac support for up to 540Mbits, waterproof enclosure, 1300mW output
http://routerboard.com/RB911G-5HPacD-NB
SXT ac
802.11ac up to 540Mbit, 1300mW RF output, low latency Point to Point
http://routerboard.com/RBSXTG-5HPacD
SXT SA ac
802.11ac up to 540Mbit, 1300mW RF output, wide beamwidth sector antenna
http://routerboard.com/RBSXTG-5HPacD-SA
And 4 different model of NetMetal 5 2x2 and 3x3!!!
5Ghz integrated 802.11ac Tripple Chain AP/Backbone/CPE, 3xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
http://routerboard.com/RB922UAGS-5HPacT-NM
5Ghz integrated 802.11ac Dual Chain AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
http://routerboard.com/RB922UAGS-5HPacD-NM
5Ghz integrated 802.11ac Tripple Chain AP/Backbone/CPE, 3xRPSMA connectors, 2000mW TX power, Gigabit Ethernet, waterproof metal enclosure
http://routerboard.com/RB921UAGS-5SHPacT-NM
5Ghz integrated 802.11ac Dual Chain AP/Backbone/CPE, 2xRPSMA connectors, 2000mW TX power, Gigabit Ethernet, waterproof metal enclosure
http://routerboard.com/RB921UAGS-5SHPacD-NM
RB911G-5HPacD
720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, onboard 1000mW 802.11ac Two Chain 5Ghz wireless, RouterOS L3
RB922UAGS-5HPacD
720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 1000mW 802.11ac Two Chain 5Ghz wireless, RouterOS L4
R11e-5HacD
5Ghz miniPCI-express, 802.11ac dual chain, 500mW, 2x MMCX
http://routerboard.com/R11e-5HacD
I'm Italian, not English. Sorry for my imperfect grammar.
nkourtzis
Re: August new products, "ac" and others...
Sat Aug 16, 2014 10:14 am
A warm welcome to the new members of the family! I am (im)patiently waiting for the store availability of the mAP and the NetMetal.
I have a question though: which antennas would you recommend for pairing with the 3 chain NetMetal, for an outdoor wide area PtMP network?
Στάλθηκε από το GT-I9100 μου χρησιμοποιώντας Tapatalk
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
rextended
Sat Aug 16, 2014 8:32 pm
It's all already on routerboard.com store!
I can't suggest one 3x3 antenna because actually I never searched that.
InoX
Sun Aug 17, 2014 3:59 pm
undiU
Sun Aug 17, 2014 8:02 pm
Hi All,
Maybe stupid question, but are the new 802.11ac routerboards backward compatible with 802.11n devices on 5Ghz?
Thanks for clarification...
Quindor
Sun Aug 17, 2014 10:54 pm
Just a quick note, the new CRS109-8G-1S-2HnD-IN is not AC wireless. Sadly the mAP isn't either.
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
normis
Mon Aug 18, 2014 9:38 am
Hi All,
Yes, of course, they support legacy 802.11n as well. There is a combined ac/n mode as well.
rextended
Mon Aug 18, 2014 9:50 pm
And where is writed which are "ac" models? :shock:
"August new products, "ac" and others... "
rextended
Mon Aug 18, 2014 9:52 pm
Having "ac" on indoor products are non-sense, because you can interfer yourself with CPE client if you use more than 20+20MHz channel...
paulchops
Tue Aug 19, 2014 2:34 am
What antennas can we use with the 3x3 radios ?
nwa
Thu Aug 21, 2014 1:12 pm
i need to buy a new AP for my Wirless and home use indoor...
i want to buy the new R11 with 802.11ac... they fall back to 5ghz n is it right ? ..
what do you think about this interaface for indoor home use in a house ???
is 500mW too much gainpower for organic brains ??? :D
can i use it or is it toooo much for the healthy ?
CyberTod
Long time Member
Long time Member
Thu Aug 21, 2014 1:35 pm
802.11ac products can fall back to n rates, they will work with older devices.
The output power can be adjusted. You can lower it from the settings and check if you have good coverage.
Users browsing this forum: heidarren and 24 guests
