Trekkie
RB922UAGS-5HPacD Question
Sun Aug 31, 2014 5:54 am
I've been waiting for this I hope :)
I'm wanting to replace some old closed access points (indoors) with these. However I'd like to still have backwards compatible 802.11b/g/n radio.
Can i just plug in a R11e-2HPnD to it? Which enclosure do you recommend?
Thank you
normis
Re: RB922UAGS-5HPacD Question
Mon Sep 01, 2014 11:04 am
802.11ac is compatible with a/n by itself. Even if you run a 802.11ac AP, the a/n devices can still use it (unless you configured otherwise).
Trekkie
Mon Sep 01, 2014 6:08 pm
:shock: oh, uh, I apparently read wrong I thought 802.11ac was 5Ghz only.
rwaters
Mon Sep 01, 2014 6:27 pm
I have rb922UAGS-5HPacD as indoor access point with R11e-2HPnD for 2.4Ghz clients. I modified a case meant for rb411/711.
I still need to drill some holes for antenna pigtails.
undiU
Wed Sep 03, 2014 10:25 pm
Normis: what about uncomfortable second question? When CA411-711 will be upgraded for rb922? Maybe also 4 antena holes finally? ;)
Users browsing this forum: adrianh and 25 guests
