adrcomms
QRT5 Ac version?
Sun Nov 09, 2014 11:57 pm
HI Microtik
Are you looking at putting the 911ac radio in the QRT5, we need a midsize panel aerial for some sites where the sxt 16db radio is to small and the 30db dish is to large, i assume that i can install the 911ac radio the QRT5 if i pop the back off.
Adrian
janisk
Re: QRT5 Ac version?
Mon Nov 10, 2014 4:30 pm
if you use router similar in form factor as one that is already there, you can easily replace them.
adrcomms
Tue Nov 11, 2014 12:31 pm
So what is the board in the QRT5?
Adrian
InoX
Tue Nov 11, 2014 12:37 pm
http://www.cdr.pl/galerie/m/mikrotik-ro ... t_5061.jpg
It might be very possible that qrt5 will be using the same board, so you can.t replace it.
honzam
Tue Nov 11, 2014 12:57 pm
This is QRT2 - it is different
QRT5 - have rb911G inside
LAN, FTTx, Wireless. ISP operator
adrcomms
Tue Nov 11, 2014 1:00 pm
So i was correct, i can replace the 911 with the 911ac board then
Adrian
normis
Tue Nov 11, 2014 1:02 pm
Adrian
yes you can!
adrcomms
Tue Nov 11, 2014 1:05 pm
Great :D
Its a shame that you do not offer a AC version of the QRT5, i will have not use for the 911 board i remove.
Thanks forum
Adrian
janisk
Tue Nov 11, 2014 3:28 pm
it seems that i forgot to add that it is RB911 in my previous post :)
normis
Wed Nov 12, 2014 11:59 am
Please excuse me, but I must correct the above. QRT is not directly compatible with the new AC boards because they have different location of the Ethernet port, and also different LED positions. This is because new series of boards have a place for SFP module, so ethernet and LEDs are shifted to the right.
Lupin
Wed Nov 12, 2014 12:24 pm
So, when you release new QRT5-AC ??
nkourtzis
Fri Nov 14, 2014 5:15 pm
We can wait for SIMPER... 8)
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
HaQs
Sat Nov 15, 2014 7:32 pm
QRT5ac with sfp and jack connector will be wonderful product
mistry7
Sun Nov 16, 2014 12:02 am
+1 for this Product from me
djdrastic
Sun Nov 16, 2014 9:34 am
Same for me.
A lot of installs I have to install the antenna directly over doors or in spaces where there is a lot of foot traffic . Getting a 5kg+ metal antenna approved by the safety beancounters at some of the places is a fricking nightmare.QRT and SXT more or less make this a non issue for me.
Lupin
Thu Dec 04, 2014 10:13 pm
Mikrotik, only a very little change to make the QRT-AC (maybe even Sextant-AC ?!?)
I need it!
Are you already thinking when releasing them ? :D
Users browsing this forum: debussy and 24 guests
